Updated on 2025-01-20 GMT+08:00
AS Groups Are in Specified VPCs
Rule Details
Table 1 Rule details
Rule Name
as-group-in-vpc
Identifier
as-group-in-vpc
If an AS group is not in any of the specified VPCs, this AS group is noncompliant.
Tag
as
Trigger Type
Configuration change
Filter Type
as.scalingGroups
Configure Rule Parameters
VpcIdList: VPC IDs
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your AS groups. For more details, see What Is Virtual Private Cloud?
Solution
You can redeploy noncompliant AS groups to required VPCs.
Rule Logic
  • If an AS group is not in any of the specified VPCs, this AS group is noncompliant.
  • If an AS group is in one of the specified VPCs, this AS group is compliant.
