Geolocation Access Control Rule Must be Configured
Rule Details
Parameter |
Description |
Rule Name |
waf-policy-enable-geoip |
Identifier |
Geolocation Access Control Rule Must be Configured |
Description |
If no geolocation access control rule is configured or is enabled for a WAF protection policy, the check result is non-compliant. |
Tag |
waf |
Trigger Type |
Periodic |
Filter Type |
Account |
Rule Parameters |
None |
Application Scenarios
WAF can identify where a request originates. You can set geolocation access control rules in just a few clicks and let WAF block or allow requests from a certain region. Custom geolocation access control rules can be set to control requests of IP addresses from specific countries or regions.
Solution
Configure geolocation access control rules to block or allow requests from specific locations.
Rule Logic
- If your account does not have a WAF protection policy with the geolocation access control rule configured or the rule is disabled, the check result is non-compliant.
- If your account has a WAF protection policy with the geolocation access control rule configured and the rule is enabled, the check result is compliant.
