WAF Instances Must Be Enabled to Protect Domain Names
Rule Details
Parameter |
Description |
Rule Name |
waf-instance-enable-protect |
Identifier |
WAF Instances Must Be Enabled to Protect Domain Names |
Description |
If no WAF instance is enabled for domain name protection, the check result is non-compliant. |
Tag |
waf |
Trigger Type |
Periodic |
Filter Type |
Account |
Rule Parameters |
None |
Application Scenarios
For users with web-based businesses, it is required to enable the Web Application Firewall (WAF) service. If WAF is enabled, all public traffic to the website will first go through the WAF. Malicious traffic will be detected and filtered by the WAF, while normal traffic will be returned to the source IP, ensuring the safety, stability, and availability of the source IP.
Solution
Enable WAF instances for your websites by following the instructions in Website Connection Overview.
Rule Logic
- If no WAF instance is enabled for domain name protection, the check result is non-compliant.
- If a WAF instance is enabled for domain name protection, the check result is compliant.
