Updated on 2025-08-25 GMT+08:00
ECSs Have Backup Vaults Attached
Rule Details
Table 1 Rule details
Rule Name
ecs-protected-by-cbr
Identifier
If an ECS is not associated with an available backup vault, this ECS is non-compliant.
Tag
cbr, ecs
Trigger Type
Configuration change
Filter Type
ecs.cloudservers
Rule Parameters
None
Application Scenarios
CBR enables you to back up ECSs and disks with ease. In case of a virus attack, accidental deletion, or software or hardware fault, you can restore data to any point in the past when the data was backed up. For details, see CBR Backup Overview. Backups are less costly than data recovery after data loss.
Solution
Create backups for your ECSs. For details, see Creating a Server Backup. Set an automatic backup policy to meet compliance requirements. For details, see Policy Management Overview.
Rule Logic
  • If an ECS is associated with an available backup vault, this ECS is compliant.
  • If an ECS is not associated with an available backup vault, this ECS is non-compliant.
