Updated on 2025-08-25 GMT+08:00
O&M Time Window Check
Rule Details
Table 1 Rule details
Rule Name
dws-maintain-window-check
Identifier
If the O&M time window of a GaussDB(DWS) cluster does not comply with the time window requirements, this cluster is non-compliant.
Tag
dws
Trigger Type
Configuration change
Filter Type
dws.clusters
Rule Parameters
  • maintainDay: Date of the O&M time window.
  • maintainStartTime: Start time of the O&M time window.
Application Scenarios
You can set the O&M time window as required. To prevent service interruption, the O&M window should fall within the off-peak hours.
The start time and end time of the O&M time window must be on the hour, and the interval between the start time and end time must be 4 hours.
Rule Logic
  • If the O&M time window of a GaussDB(DWS) cluster does not comply with the time window requirements, this cluster is non-compliant.
  • If the O&M time window of a GaussDB(DWS) cluster complies with the time window requirements, this cluster is compliant.
