Updated on 2025-08-25 GMT+08:00
Disk Encryption Are Enabled
Rule Details
Table 1 Rule details
Rule Name
volumes-encrypted-check-by-default
Identifier
If an EVS disk is not encrypted, this disk is non-compliant.
Tag
evs
Trigger Type
Configuration change
Filter Type
evs.volumes
Rule Parameters
None
Application Scenarios
EVS disks may contain sensitive data. Attached EVS disks must be encrypted. Encryption ensures data confidentiality and reduces the risk of unauthorized access to data.
Solution
Encrypt your EVS disks. For details, see Managing Encrypted EVS Disks
Rule Logic
  • If an EVS disk is encrypted, this disk is compliant.
  • If an EVS disk is not encrypted, this disk is non-compliant.
