Login Protection Check
Rule Details
Parameter |
Description |
Rule Name |
iam-user-login-protection-enabled |
Identifier |
Description |
If login protection is not enabled for an IAM user, this user is noncompliant. |
Tag |
iam |
Trigger Type |
Configuration change |
Filter Type |
iam.users |
Rule Parameter |
None |
Applicable Scenario
To improve account security and prevent phishing attacks and password leakage, the root or administrative user can enable login protection for IAM users. If login protection is enabled, a verification code will be required in addition to the username and password during login. You can use a mobile number, email address, or virtual MFA for login authentication.
Solution
You can enable login protection for the noncompliant IAM users. For more details, see Login Protection.
Rule Logic
- If an IAM user is in the disabled state, this user is compliant.
- If an IAM user that is enabled has MFA enabled, this user is compliant.
- If an IAM user that is enabled does not have MFA enabled, this user is noncompliant.
