The Slow Query Log Is Enabled
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-enable-slowlog |
Identifier |
Description |
If the slow query log is not enabled for a TaurusDB instance, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
You can download slow query logs of TaurusDB instances. Slow query log allows you to:
- Record SQL queries whose execution duration exceeds the threshold.
- Optimize performance through slow query analysis.
- Monitor database resource usage to prevent resource exhaustion.
Solution
Enable LTS slow query logging. For details, see Configuring Log Reporting.
Rule Logic
- If slow query logging is not enabled for a TaurusDB instance, this instance is non-compliant.
- If slow query logging is enabled for a TaurusDB instance, this instance is compliant.
