Error Logging Is Enabled
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-enable-errorlog |
Identifier |
Description |
If the error log is not enabled for a TaurusDB instance, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
You can download error logs of TaurusDB instances. Error log can:
- Record error information on database running, such as startup failures, breakdowns, and SQL syntax errors.
- Help administrators quickly locate and rectify faults.
- Record security events such as unauthorized access attempts for audit.
Solution
Enable LTS error logging. For details, see Configuring Log Reporting.
Rule Logic
- If error logging is not enabled for a TaurusDB instance, this instance is non-compliant.
- If error logging is enabled for a TaurusDB instance, this instance is compliant.
