The Audit Log Reporting Is Enabled
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-mysql-instance-enable-auditlog |
Identifier |
Description |
If the audit log is reporting not enabled for a TaurusDB instance, this instance is non-compliant. |
Tag |
taurusdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdbformysql.instance |
Rule Parameters |
None |
Application Scenarios
The audit function records all user activities on databases. You can view audit logs to perform security assessments and pinpoint problem causes, thereby enhancing system operational efficiency.
If you enable log reporting, audit logs generated by TaurusDB instances will be uploaded to Log Tank Service (LTS) for management. For details, see Configuring Log Reporting.
Solution
Enable audit log reporting. For details, see Configuring Log Reporting.
Rule Logic
- If audit log reporting is not enabled for a TaurusDB instance, this instance is non-compliant.
- If audit log reporting is enabled for a TaurusDB instance, this instance is compliant.
