Error Log Collection Is Enabled
Rule Details
Parameter |
Description |
Rule Name |
gaussdb-instance-enable-errorLog |
Identifier |
Description |
If error log collection is not enabled for a GaussDB instance, this instance is non-compliant. |
Tag |
gaussdb |
Trigger Type |
Configuration change |
Filter Type |
gaussdb.instance |
Rule Parameters |
None |
Application Scenarios
GaussDB allows you to download slow query logs and error logs. Slow query logs help you locate slow SQL statement execution problems. Error logs help you locate instance problems. For details, see Downloading Error Logs and Slow Query Logs of a GaussDB Instance.
Solution
The error log collection is enabled by default. No action is required.
Rule Logic
- If error log collection is disabled, the GaussDB instance is non-compliant.
- If error log collection is enabled, the GaussDB instance is compliant.
