DMS RocketMQ Instances Have SSL Enabled
Rule Details
| Parameter | Description |
| Rule Name | dms-rocketmq-not-enable-ssl |
| Identifier | DMS RocketMQ Instances Have SSL Enabled |
| Description | If a DMS RocketMQ instance does not have SSL enabled, this instance is non-compliant. |
| Tag | dms |
| Trigger Type | Configuration change |
| Filter Type | dms.reliabilitys |
| Rule Parameters | None |
Application Scenarios
To ensure that data is not stolen or damaged during transmission, enable SSL access.
Solution
Enable SSL access for RockctMQ. For details, see Accessing RockctMQ on a Client (with SSL).
Rule Logic
- If ciphertext public network access is not enabled for a DMS for RocketMQ instance, this instance is non-compliant.
- If ciphertext public network access is enabled for a DMS for RocketMQ instance, this instance is compliant.
