SSL Is Enabled for DMS RabbitMQ Queues
Rule Details
Parameter |
Description |
Rule Name |
dms-rabbitmq-not-enable-ssl |
Identifier |
SSL Is Enabled for DMS RabbitMQ Queues |
Description |
If SSL is not enabled for a RabbitMQ queue, this instance is non-compliant. |
Tag |
dms |
Trigger Type |
Configuration change |
Filter Type |
dms.rabbitmqs |
Rule Parameters |
None |
Application Scenarios
To ensure that data is not stolen or damaged during transmission, enable SSL access.
Solution
Enable SSL access for RabbitMQ. For details, see Accessing RabbitMQ on a Client (SSL Enabled).
Rule Logic
- If ciphertext public network access is not enabled for a DMS for RabbitMQ instance, this instance is non-compliant.
- If ciphertext public network access is enabled for a DMS for RabbitMQ instance, this instance is compliant.
