Updated on 2025-08-25 GMT+08:00
Access Key Used Within the Specified Period
Rule Details
Table 1 Rule details
Rule Name
access-keys-last-use-check
Identifier
If the access key of an IAM user is not used within a specified period, the check result is non-compliant.
Tag
iam
Trigger Type
Periodic
Filter Type
iam.users
Rule Parameters
maxAccessKeyIdleDay: Maximum number of days an access key remain unused
evaluateDisabledUser: Whether to evaluate disabled users
Application Scenarios
Enterprise users usually use access keys (AK/SK) to access cloud resources through APIs. You need to delete idle access keys to reduce potential security risks, such as key leakage.
Solution
Delete idle access keys on the console.
Rule Logic
  • If an IAM user does not have an access key, the check result is compliant.
  • If the access key of an IAM user has been used within the specified period, the check result is compliant.
  • If the access key of an IAM user has not been used within the specified period, the check result is non-compliant.
