Updated on 2025-10-13 GMT+08:00
Expiration Check for Private Certificates
Rule Details
Table 1 Rule details
Rule Name
pca-certificate-expiration-check
Identifier
If the validity period of a private certificate is not within the specified range, this certificate is non-compliant.
Tag
pca
Trigger Type
Periodic
Filter Type
pca.cert
Rule Parameters
daysToExpiration: indicates a validity period. This is an integer type parameter.
Application Scenarios
Private certificates are deployed on service nodes and are frequently used for encrypted communication. To prevent private key leakage, the validity period of private certificates is set based on the security level requirements of service scenarios. If a private certificate expires, service communication will be interrupted.
Solution
Rotate your private certificate, or renew the private certificate in the Billing Center.
Rule Logic
  • If a private certificate will expire within the specified period, this policy is non-compliant.
  • If a private certificate will not expire within the specified period, this policy is compliant.
