EVS Disks Are Encrypted
Rule Details
Parameter |
Description |
Rule Name |
volumes-encrypted-check |
Identifier |
Description |
If a mounted EVS disk is not encrypted, this disk is non-compliant. |
Tag |
evs, ecs |
Trigger Type |
Configuration change |
Filter Type |
evs.volumes |
Rule Parameters |
None |
Application Scenarios
EVS disks may contain sensitive data. Attached EVS disks must be encrypted. Encryption ensures data confidentiality and reduces the risk of unauthorized access to data.
Solution
Encrypt your EVS disks. For details, see Managing Encrypted EVS Disks
Rule Logic
- If an EVS disk is not attached, this disk is compliant.
- If an EVS disk is attached and encrypted, this disk is compliant.
- If an EVS disk is attached but not encrypted, this disk is non-compliant.
