Idle EVS Disk Check
Rule Details
Parameter |
Description |
Rule Name |
volume-unused-check |
Identifier |
Description |
If an EVS disk is not mounted to any cloud server, this disk is non-compliant. |
Tag |
evs |
Trigger Type |
Configuration change |
Filter Type |
evs.volumes |
Rule Parameters |
None |
Application Scenarios
If an EVS is no longer needed, you are advised to delete it to save costs. If the EVS contains sensitive information, deleting it can reduce security risks.
Solution
If an EVS disk is required, attach it by referring to Attaching an EVS Disk.
If an EVS disk is no longer required, unsubscribe from or delete it by referring to Unsubscribing from or Deleting an EVS Disk
Rule Logic
- If an EVS disk has been attached, this disk is compliant.
- If an EVS disk is not attached, this disk is non-compliant.
