- What's New
- Getting Started
User Guide
- Resource List
- Resource Recorder
Resource Compliance
- Overview
- Rules
- Organization Rules
- Viewing Noncompliant Resources
- Compliance Rule Concepts
Built-In Policies
- Predefined Policy List
General Policies
- Resource Names Meet Regular Expression Requirements
- Resources Have All the Specified Tags Attached
- Resources Have One of the Specified Tags Attached
- Tag Prefixes and Suffixes Check
- Resources Have at Least One Tags Attached
- Resource Tag Check
- Resources Are in Specified Enterprise Projects
- Resources Are in Specified Regions
- Resource Type Check by Specifying Allowed Resource Types
- Resource Type Check by Specifying Unallowed Resource Types
- API Gateway
- CodeArts Deploy
- MapReduce Service
- NAT Gateway
- VPC Endpoint
- Web Application Firewall
- Elastic Load Balance
- Elastic IP
- Auto Scaling
- Scalable File Service Turbo (SFS Turbo)
- Flavor Check
- Image Check
- Image Check by Tag
- Security Group Check by ID
- VPC Check by ID
- ECSs Have Key Pairs Attached
- ECSs Cannot Be Accessed Through Public Networks
- An ECS Does Not Have Multiple EIPs Attached
- Idle ECS Check
- ECSs Have IAM Agencies Attached
- Image Check by Name
- ECSs Have Backup Vaults Attached
- Backup Time Check
- ECSs Have HSS Agents Attached
- DCS Memcached Instances Support SSL
- DCS Memcached Instances Are in a Specified VPC
- DCS Memcached Instances Do Not Have EIPs Attached
- Access Mode Check
- DCS Redis Instances Support SSL
- Cross-AZ Deployment Check
- DCS Redis Instances Are in the Specified VPC
- DCS Redis Instances Do Not Have EIPs Attached
- Access Mode Check
- FunctionGraph
- Content Delivery Network (CDN)
- Config
- Data Warehouse Service
- Data Replication Service
- Data Encryption Workshop
- Key Rotation Check
- IAM Policies Do Not Allow Blocked Actions on KMS Keys
- Each User Group Has at Least One User
- Password Strength Check
- Unintended Policy Check
- Admin Permissions Check
- Custom Policies Do Not Allow All Actions for a Service
- The Root User Does Not Have Available Access Keys
- Access Mode Check
- Access Key Check
- IAM Users Are in Specified User Groups
- Last Login Check
- Multi-Factor Authentication Check
- A User Does Not have Multiple Active Access Keys
- MFA Has Been Enabled for Console Login
- The Root User Has MFA Enabled
- All IAM Policies Are in Use
- All IAM Roles Are in Use
- Login Protection Check
- IAM Agencies Contain Specified Policies
- The Admin User Group Only Contains the Root User
- IAM Users Do Not Have Directly Assigned Policies or Permissions
- Document Database Service
- Simple Message Notification
- Virtual Private Cloud
- Virtual Private Network
- Cloud Eye
- Cloud Container Engine
- CTS Trackers Have Traces Encrypted
- CTS Trackers Have Trace Transfer to LTS Enabled
- CTS Trackers Have Been Created for the Specified OBS Bucket
- Trace File Verification Is Enabled
- At Least One Tracker Is Enabled
- There Are CTS Trackers In the Specified Regions
- CTS Trackers Comply with Security Best Practices
- Error Log Collection Is Enabled for RDS Instances
- RDS Instances Support Slow Query Logs
- Single-AZ Cluster Check
- RDS Instances Do Not Have EIPs Attached
- RDS Instances Use KMS Encryption
- RDS Instances Are in the Specified VPC
- Both Error Logs and Slow Query Logs Are Collected for RDS Instances
- Flavor Check
- RDS Instances Have SSL Enabled
- RDS Instance Port Check
- Version Check for RDS Instance Engines
- RDS Instances Have Audit Log Enabled
- GaussDB
- TaurusDB
- GeminiDB
- CSS Clusters Have the Security Mode Enabled
- The Snapshot Function Is Enabled for CSS Clusters
- Disk Encryption Is Enabled for CSS Clusters
- HTTPS Access Is Enabled for CSS Clusters
- CSS Clusters Are in Specified VPCs
- Single-AZ CSS Cluster Check
- A CSS Cluster Has at Least Two Instances
- CSS Clusters Are Not Publicly Accessible
- CSS Clusters Support the Security Mode
- CSS Clusters Have Access Control Enabled
- CSS Clusters Have Kibana Public Access Control Enabled
- CSS Clusters Have Slow Query Log Enabled
- Elastic Volume Service
- Cloud Certificate Manager
- Distributed Message Service for Kafka
- Distributed Message Service for RabbitMQ
- Distributed Message Service for RocketMQ
- Organizations
- Cloud Firewall
- Cloud Backup and Recovery
- Object Storage Service
- Image Management Service
- Bare Metal Server
- Graph Engine Service
- Resource Compliance Event Monitoring
Conformance Packages
- Overview
- Conformance Packages
- Organization Conformance Packages
- Custom Conformance Packages
Conformance Package Templates
- Overview
- Conformance Package for Classified Protection of Cybersecurity Level 3 (2.0)
- Conformance Package for the Financial Industry
- Conformance Package for Network Security
- Conformance Package for Identity and Access Management
- Conformance Package for Cloud Eye
- Conformance Package for Compute Services
- Conformance Package for ECS
- Conformance Package for ELB
- Conformance Package for Management and Regulatory Services
- Conformance Package for RDS
- Conformance Package for AS
- Conformance Package for CTS
- Conformance Package for AI and Machine Learning
- Conformance Package for Autopilot
- Conformance Package for Enabling Public Access
- Conformance Package for Logging and Monitoring
- Conformance Package for Architecture Reliability
- Conformance Package for Hong Kong Monetary Authority of China Requirements
- Conformance Package for ENISA Requirements
- Conformance Package for SWIFT CSP
- Conformance Package for Germany Cloud Computing Compliance Criteria Catalogue
- Conformance Package for PCI DSS
- Conformance Package for Healthcare Industry
- Best Practices of Network and Data Security
- Conformance Package for Landing Zone
- Architecture Security Best Practices
- Best Practices for Network and Content Delivery Service Operations
- Best Practices for Idle Asset Management
- Multi-AZ Deployment Best Practices
- Resource Stability Best Practices
- Best Practices for API Gateway
- Best Practices for Cloud Container Engine
- Best Practices for Content Delivery Network
- Best Practices for FunctionGraph
- Best Practices for GaussDB
- Best Practices for GeminiDB
- Best Practices for MapReduce Service
- Best Practices for NIST Requirements
- Best Practices for Singapore Financial Industry
- Best Practices for Secure Identity and Compliance Operations
- Conformance Package for Huawei Cloud Security Configuration Guide (Level 1)
- Conformance Package for Huawei Cloud Security Configuration Guide (Level 2)
- Best Practices for Static Data Encryption
- Best Practices for Data Transmission Encryption
- Best Practices for Cloud Backup and Recovery
- Best Practices for Cloud Search Service
- Best Practices for Distributed Cache Service
- Best Practices for Distributed Message Service
- Best Practices for Data Warehouse Service
- Best Practices for TaurusDB
- Best Practices for Object Storage Service
- Best Practices for Virtual Private Cloud
- Best Practices for Web Application Firewall
- Advanced Queries
- Resource Aggregation
- Cloud Trace Service
- Appendix
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Resource List
- Querying Resources of a Specific Type
- Querying Cloud Services
- Querying a Resource
- Querying All Resources Recorded by the Resource Recorder
- Querying How Many Resources Are Recorded by the Resource Recorder
- Querying Resource Tags Recorded by the Resource Recorder
- Querying Resource Overview Recorded by the Resource Recorder
- Querying a Specific Resource Recorded by the Resource Recorder
- Querying All Resources Under an Account
- Querying a Resource Under an Account
- Querying the Number of Resources
- Resource Recorder
- Resource Relationships
- Resource Change Records
Compliance
- Querying Built-in Policies
- Querying Specific Built-in Policy
- Adding a Rule
- Querying Rules
- Modifying a Rule
- Querying a Specific Rule
- Deleting a Rule
- Enabling a Rule
- Disabling a Rule
- Running a Resource Compliance Evaluation
- Querying the Evaluation Status of a Rule
- Querying the Compliance of a Resource
- Querying the Compliance of a Rule
- Querying Compliance of an Account
- Updating the Compliance Result
- Creating an Organization Rule
- Querying Organization Rules
- Querying a Specific Organization Rule
- Deleting an Organization Rule
- Updating an Organization Rule
- Querying the Deployment Status of an Organization Rule
- Querying Statuses of Organization Rule Deployment to Member Accounts
- Setting up or Updating Remediation Configurations
- Querying Remediation Configurations
- Deleting Remediation Configurations
- Batch Creating Remediation Exceptions
- Batch Deleting Remediation Exceptions
- Querying Remediation Exceptions
- Starting Remediation
- Querying Remediation Results
- Collect Remediation Results
- Region Management
- Advanced Queries
Resource Aggregators
- Creating a Resource Aggregator
- Querying Resource Aggregators
- Querying a Specific Resource Aggregator
- Querying Account Aggregation Statuses of a Specific Aggregator
- Updating a Resource Aggregator
- Deleting a Resource Aggregator
- Authorizing an Aggregator Account
- Querying Authorized Aggregator Accounts
- Deleting Authorization for an Aggregator Account
- Querying All Pending Aggregation Requests
- Deleting Pending Authorization Requests
- Querying the Number of Resources of an Aggregator Account
- Querying Resources of an Aggregator Account
- Querying Details About a Specific Resource in a Source Account
- Performing an Advanced Query on a Specific Aggregator
- Querying the Compliance Summary of One or More Source Accounts in an Aggregator
- Querying Aggregated Rules
- Querying Compliance Results of Aggregated Resources
- Querying Details About a Specified Aggregated Rule
- Querying Conformance Packages
- Creating a Conformance Package
- Querying a Specific Conformance Package
- Deleting a Conformance Package
- Updating Conformance Packages
- Querying Compliance of all Conformance Packages
- Querying Compliance of all Rules in a Conformance Package
- Querying Compliance of All Resources Evaluated with a Conformance Package
- Querying Scores of All Conformance Packages
- Querying Built-in Conformance Package Templates
- Querying the Template of a Built-in Conformance Package
- Creating organization conformance packages.
- Querying Organization Conformance Packages
- Querying an Organization Conformance Package
- Delete organization conformance packages.
- Updating Organization Conformance Packages
- Querying the Deployment Status of the Organization Conformance Package
- Querying the Statuses of Organization Conformance Package Deployment to Members.
- Resource Tags
Resource List
- Appendixes
- SDK Reference
Best Practices
- Creating Rules
- Querying Resource Details, Relationships, and Change Records
- Creating Alarm Rules for Noncompliant Resources with Cloud Eye
- Using Advanced Queries
- Querying Resources That Do Not Have Specific Tags
- Ensuring Resource Compliance by Tag, Region, and Organization
- Automating Resource Management
- FAQs
Show all
Disks Are Used Within the Specified Time
Rule Details
Parameter |
Description |
Rule Name |
evs-use-in-specified-days |
Identifier |
Description |
If an EVS disk has not been used within the specified time range after being created, this disk is noncompliant. |
Tag |
evs |
Trigger Type |
Periodic |
Filter Type |
evs.volumes |
Configure Rule Parameters |
allowDays: indicates the maximum number of days that a disk is allowed to remain unused. This is a numeric type parameter. |
