CSS Clusters Are in Specified VPCs
Rule Details
Parameter |
Description |
Rule Name |
css-cluster-in-vpc |
Identifier |
Description |
If a CSS cluster is not in any of the specified VPCs, this cluster is noncompliant. |
Tag |
css |
Trigger Type |
Configuration change |
Filter Type |
css.clusters |
Configure Rule Parameters |
authorizedVpcIds: VPC IDs. If the list is left blank, all values are allowed. The value must be an array with up to 10 elements. |
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your CSS clusters. For more details, see What Is Virtual Private Cloud?
Solution
You can redeploy noncompliant CSS clusters to required VPCs.
Rule Logic
- If a CSS cluster is not in any of the specified VPCs, this cluster is noncompliant.
- If a CSS cluster is in one of the specified VPCs, this cluster is compliant.
