RDS DB Instances Should Not Use EIPs
Rule Details
Parameter |
Description |
Rule Name |
rds-instance-no-public-ip |
Identifier |
RDS DB Instances Should Not Use EIPs |
Description |
If an RDS instance has an EIP attached, this RDS instance is non-compliant. |
Tag |
rds |
Trigger Type |
Configuration change |
Filter Type |
rds.instances |
Rule Parameters |
None |
Application Scenarios
RDS instances should not be deployed on the Internet or in a DMZ. Instead, they should be deployed on the internal network of your company. Use routers or firewalls to protect them, and do not bind EIPs to your RDS instances. This prevents unauthorized access and DDoS attacks. If your RDS instances must use EIPs, set security group rules to restrict access from source IP addresses. For details, see Security Best Practices
Solution
Do not attach EIPs to your RDS instances. Detach EIPs from your RDS instances.
Rule Logic
- If an RDS instance has an EIP attached, this instance is non-compliant.
- If an RDS instance does not have an EIP attached, this instance is compliant.
