Oldest Supported Version Check
Rule Details
Parameter |
Description |
Rule Name |
cce-cluster-oldest-supported-version |
Identifier |
Oldest Supported Version Check |
Description |
If a CCE cluster is running the oldest supported version, this cluster is non-compliant. |
Tag |
cce |
Trigger Type |
Configuration change |
Filter Type |
cce.clusters |
Rule Parameters |
None |
Application Scenarios
The latest cluster version has known vulnerabilities fixed or provides a more comprehensive security protection mechanism. You are advised to select the latest cluster version when creating a cluster. Before a cluster version is deprecated and removed, upgrade your cluster to a supported version.
The earliest supported version is 1.13. For details, see Cluster Version Release Notes.
Solution
Rule Logic
- If a CCE cluster is running the oldest supported version, this cluster is non-compliant.
- If a CCE cluster is running a version later than the earliest supported version, this cluster is compliant.
