Connection State Check
Rule Details
Parameter |
Description |
Rule Name |
vpn-connections-active |
Identifier |
Connection State Check |
Description |
If a VPN connection is not ACTIVE, the check result is non-compliant. |
Tag |
vpnaas |
Trigger Type |
Configuration change |
Filter Type |
vpnaas.vpnConnections, vpnaas.ipsec-site-connections |
Rule Parameters |
None |
Application Scenarios
After a VPN gateway is created, you need to create a VPN connection to ensure network connectivity.
The VPN connection state can be ERROR, ACTIVE, DOWN, PENDING_CREATE, PENDING_UPDATE, PENDING_DELETE. FREEZED, or UNKNOWN.
Solution
Rectify the fault based on the troubleshooting guidance for The State of a VPN Connection Is Not connected.
Rule Logic
- If a VPN connection is not ACTIVE, the check result is non-compliant.
- If a VPN connection is ACTIVE, the check result is compliant.
