VPCs Have Enabled Flow Logs
Rule Details
Parameter |
Description |
Rule Name |
vpc-flow-logs-enabled |
Identifier |
VPCs Have Enabled Flow Logs |
Description |
If flow logging is not enabled for all VPCs, this VPC is non-compliant. |
Tag |
vpc |
Trigger Type |
Configuration change |
Filter Type |
vpc.vpcs |
Rule Parameters |
None |
Application Scenarios
VPC flow logs help you collect traffic information about instances in a specified VPC, including inbound and outbound traffic. After creating a VPC flow log, you can view the flow log records in the configured log group. For details, see VPC Flow Log. Flow logs can help you:
- Monitor the traffic of security groups and network ACLs, and refine the control rules of security groups and network ACLs.
- Monitor the traffic of network instances and analyze network attacks.
- Determine the direction of the traffic to and from network interfaces.
Solution
Rule Logic
- If a VPC does not have flow logging enabled, this VPC is non-compliant.
- If flow logging is enabled for a VPC, this VPC is compliant.
