Log Reporting to LTS Has Been Enabled
Rule Details
Parameter |
Description |
Name |
smn-lts-enable |
Identifier |
Log Reporting to LTS Has Been Enabled |
Description |
If Report Logs to LTS has not been enabled for a topic, this topic is non-compliant. |
Tag |
smn |
Trigger Type |
Configuration change |
Filter Type |
smn.topic |
Rule Parameters |
None |
Application Scenarios
You can use logs when you want to know the statuses of messages published to a topic. Protocols including SMS, email, FunctionGraph (function), FunctionGraph (workflow), HTTP, and HTTPS are supported. To enable logging, you need to interconnect SMN with LTS and create a log group and a log stream on the LTS console.
Solution
Rule Logic
- If message transmission logging has not been enabled for an SMN topic, this topic is non-compliant.
- If message transmission logging has been enabled for an SMN topic, this topic is compliant.
