Updated on 2025-08-25 GMT+08:00
DDS Instances Should Not Use EPIs
Rule Details
Table 1 Rule details
Rule Name
dds-instance-has-eip
Identifier
If a DDS instance has an EIP attached, this instance is non-compliant.
Tag
dds
Trigger Type
Configuration change
Filter Type
dds.instances
Rule Parameters
None
Application Scenarios
DDS instances should not be deployed on the Internet or in a DMZ. Instead, they should be deployed on the internal network of your company. Use routers or firewalls to protect them and do not bind EIPs to your DDS instances. This prevents unauthorized access and DDoS attacks. If your DDS instances must access public net work through EIPs, you must set security groups. For details, see Security Best Practices.
Solution
Do not allow public network connection to your instances. Refer to Connection Methods for other connection methods.
Rule Logic
  • If a DDS instance has an EIP attached, this instance is non-compliant.
  • If a DDS instance does not have an EIP attached, this instance is compliant.
