DDS Instance Type Check
Rule Details
Parameter |
Description |
Rule Name |
dds-instance-hamode |
Identifier |
DDS Instance Type Check |
Description |
If a DDS instance is not of the specified type, this instance is non-compliant. |
Tag |
dds |
Trigger Type |
Configuration change |
Filter Type |
dds.instances |
Rule Parameters |
haMode: indicates the specified instance type. The value must be a string. |
Application Scenarios
DDS instances can be deployed based on a cluster, replica set, or single node architecture.
- Clusters are suitable for scenarios demanding high availability, high scalability, and large service system data storage.
- Replica sets are suitable for small- and medium-sized service systems that require high availability.
- Single-node instances fit temporary use of databases such as business R&D, SQL commissioning, and lab project tests. These instances have reached EOS since July 15, 2023.
Solution
Purchase a cluster instance or replica set instance based on your needs.
Rule Logic
- If the DDS instance architecture does not match the specified type, this instance is non-compliant.
- If the DDS instance architecture matches the specified type, this instance is compliant.
