Updated on 2025-08-25 GMT+08:00
Editing a Remediation Configuration
You can create only one remediation configuration for a compliance rule. You can edit the configuration anytime after creation.
  2. Click in the upper left corner of the page. Under Management & Governance, select Config.
  3. In the navigation pane on the left, choose Resource Conformance.
  4. On the Rules tab, click the name of a rule that has remediation configured to go to the details page.
  5. Click the Remediation tab.
  6. In the upper right corner of the page, click Edit. On the displayed page, modify the parameters.
    Figure 1 Editing remediation configurations
  7. Click Save.
