Manual Remediation
If you select Manual for Remediation Method, you need to manually remediate the non-compliant configurations of your resources.
Even if you select Automatic for Remediation Method, you can still manually remediate the non-compliant configurations of your resources.
The remediation statuses of resources are as follows:
- Queuing: The remediation is pending.
- Processing: The non-compliant resource configurations are being corrected.
- Success: The non-compliant resource configurations have been remediated.
- Failed: Remediation failed. You can view the failure cause on the page.
Remediating All Non-compliant Resources
- Click
in the upper left corner of the page. Under Management & Governance, select Config. - In the navigation pane on the left, choose Resource Conformance.
- In the Rules tab, locate the target rules that have remediation actions configured and click More > Remediate in the Operation column.
- In the displayed dialog box, click OK to deliver the remediation request.
All non-compliant resources detected by the compliance rule will be remediated sequentially.
Figure 1 Remediating
- Click the name of the target rule to go to the Rule Details page.
- Click the Rectification tab. In the Resource Scope pane in the lower part of the page, view the remediation information about all non-compliant resources.
You can click the refresh button in the upper right corner of the pane to update remediation status.
Figure 2 Checking remediation results
Remediating Specific Non-compliant Resources
- Click
- On the Rules tab, click the name of a rule that has remediation configured to go to the details page.
- In the Resource Scope pane, select one or more non-compliant resources, and click Remediate above the list.
Figure 3 Executing remediation
- In the Resource Scope pane, check the remediation information of the selected non-compliant resources.
Figure 4 Checking remediation results
