Updated on 2025-09-09 GMT+08:00
Viewing Non-Compliant Resources
You can view all non-compliant resources in the Non-Conforming Resources tab of the Resource Conformance page.
- Click
in the upper left corner of the page. Under Management & Governance, select Config.
- In the navigation pane on the left, choose Resource Conformance.
- Click Non-Conforming Resources. All non-compliant resources from the current account are displayed in a list.
- Click a resource name to view resource overview.
Above the list, you can filter non-compliant resources with multiple search options. You can also export the list.
Figure 1 Viewing non-conforming resources
Parent topic: Resource Compliance
