Private CA Algorithm Check
Updated on 2024-12-10 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
pca-algorithm-check
Identifier
Algorithm Check
If a private certificate or CA prohibits key-based algorithms or signature-based hash algorithms, the private certificate or CA is noncompliant.
Tag
pca
Trigger Type
Configuration change
Filter Type
pca.ca, pca.cert
Configure Rule Parameters
  • blockedKeyAlgorithm: key algorithms. The value must be an array, for example, ["SM2", "RSA2048", "EC256"].
  • blockedSignatureAlgorithm: signature algorithms. The value must be an array, for example, ["SHA256"].
Applicable Scenario
Secure algorithms are critical for private CA and certificate security. You are advised to use algorithms that can ensure enough security for your resources. This will not costs much as they used to.
Solution
You can remove noncompliant private CAs and certificates, and purchase new ones that meet your security requirements.
Rule Logic
  • If a private certificate or CA prohibits key-based algorithms or signature-based hash algorithms, the private certificate or CA is noncompliant.
  • If a private certificate or CA does not prohibit key-based algorithms or signature-based hash algorithms, the private certificate or CA is compliant.
