TLS Version Check
Rule Details
Parameter |
Description |
Rule Name |
cdn-security-policy-check |
Identifier |
TLS Version Check |
Description |
If a CDN domain uses a TLS version earlier than 1.2, this domain is non-compliant. |
Tag |
cdn |
Trigger Type |
Configuration change |
Filter Type |
cdn.domains |
Rule Parameters |
None |
Application Scenarios
You can configure TLS versions for your domain names as required. TLS 1.0, TLS 1.1, TLS 1.2, and TLS 1.3 are available. A later version is more secure, but is less compatible with browsers of earlier versions.
Solution
Rule Logic
- If a CDN domain uses a TLS version earlier than 1.2, this domain is non-compliant.
- If a CDN domain uses TLS 1.2 or a later version, this domain is compliant.
