Updated on 2025-01-20 GMT+08:00
DCS Redis Instances Are in the Specified VPC
Rule Details
Table 1 Rule details
Rule Name
dcs-redis-in-vpc
Identifier
dcs-redis-in-vpc
If a DCS Redis instance is not in the specified VPC, this instance is noncompliant.
Tag
dcs
Trigger Type
Configuration change
Filter Type
dcs.redis
Configure Rule Parameters
vpcId: The VPC ID. The value must be a string.
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your DCS Redis instances. For more details, see What Is Virtual Private Cloud?
Solution
You can redeploy noncompliant DCS Redis instances to required VPCs. For details, see Viewing and Modifying Basic Settings of a DCS Instance.
Rule Logic
  • If a DCS Redis instance is not in the specified VPC, this instance is noncompliant.
  • If a DCS Redis instance is in the specified VPC, this instance is compliant.
