DCS for Memcached Instances Support SSL
Rule Details
Parameter |
Description |
Rule Name |
dcs-memcached-enable-ssl |
Identifier |
DCS for Memcached Instances Support SSL |
Description |
If a DCS for Memcached instance can be accessed through public networks but does not support SSL, this instance is non-compliant. |
Tag |
dcs |
Trigger Type |
Configuration change |
Filter Type |
dcs.memcached |
Rule Parameters |
None |
Application Scenarios
You need to ensure that SSL encryption is enabled for data transmission if your DCS for Memcached resources can be accessed through public networks.
Solution
To enable SSL encryption, you can enable SSL and configure an SSL certificate on the SSL settings page. DCS for Memcached has been discontinued. Use DCS for Redis instead. For details, see Huawei Cloud Distributed Cache Service Memcached Is Discontinued.
Rule Logic
- If your DCS for Memcached instances are not accessible through public networks, the check result is compliant.
- If DCS for Memcached instances are accessible through public networks and SSL encryption is enabled, the check result is compliant.
- If DCS for Memcached instances are accessible through public networks but SSL encryption is disabled, the check result is non-compliant.
