Updated on 2025-08-25 GMT+08:00
CSS Cluster Update Check
Rule Details
Table 1 Rule details
Rule Name
css-cluster-update-check
Identifier
If a CSS cluster does not have the latest update installed, this cluster is non-compliant.
Tag
css
Trigger Type
Configuration change
Filter Type
css.clusters
Rule Parameters
None
Application Scenarios
You can call the API to obtain the ID of the target image to upgrade to.
Solution
Upgrade the images of your CSS clusters in a timely manner.
Rule Logic
  • If the CSS cluster has images that need to be upgraded, this cluster is non-compliant.
  • If the CSS cluster does not have images that need to be upgraded, this cluster is compliant.
