Updated on 2025-01-22 GMT+08:00
CSS Clusters Have Slow Query Log Enabled
Rule Details
Table 1 Rule details
Rule Name
css-cluster-slowLog-enable
Identifier
If a CSS cluster does not have slow query log enabled, this cluster is noncompliant.
Tag
css
Trigger Type
Configuration change
Filter Type
css.clusters
Configure Rule Parameters
None
Applicable Scenario
Elasticsearch and OpenSearch clusters provide deprecation logs, run logs, index slow logs, and search slow logs for users to trouble shoot related issues. For details, see Querying and Managing Elasticsearch Cluster Logs.
Solution
By default, CSS clusters provide slow query logs. If you need longer storage, you can dump the logs into an OBS bucket. For details, see Modifying Basic Log Configurations.
Rule Logic
  • If a CSS cluster has slow query log disabled, this cluster is noncompliant.
  • If a CSS cluster has slow query log enabled, this cluster is compliant.
