ECS Instances Are in the Specified VPC
Rule Details
Parameter |
Description |
Rule Name |
ecs-instance-in-vpc |
Identifier |
ECS Instances Are in the Specified VPC |
Description |
If an ECS is not in the specified VPC, this ECS is non-compliant. |
Tag |
ecs, vpc |
Trigger Type |
Configuration change |
Filter Type |
ecs.cloudservers |
Rule Parameters |
vpcId: VPC ID of an ECS |
Application Scenarios
A VPC is a private network on the cloud. You can create VPCs to logically isolate your resources. When creating a VPC, you can configure security groups, VPN, IP address segments, and bandwidth. This facilitates internal network management and configuring, allowing you to change network configurations in a secure, convenient manner. Additionally, you can control ECS access within and across security groups to enhance security.
For more information about VPC, see What Is Virtual Private Cloud?
Solution
You cannot change the VPC of an ECS. Exercise cause when selecting a VPC.
Rule Logic
- If an ECS is not in the specified VPC, this ECS is non-compliant.
- If an ECS is in the specified VPC, this ECS is compliant.
