ELB Listeners Have Specified Security Policies Added
Rule Details
Parameter |
Description |
Rule Name |
elb-predefined-security-policy-https-check |
Identifier |
ELB Listeners Have Specified Security Policies Added |
Description |
If a specified security policy is not configured for the HTTPS listener of a dedicated load balancer, this dedicated load balancer is non-compliant. |
Tag |
elb |
Trigger Type |
Configuration change |
Filter Type |
elb.loadbalancers |
Rule Parameters |
predefinedPolicyName: indicates the specified security policy. The default value is tls-1-0. Example values: tls-1-0, tls-1-1, tls-1-2, tls-1-0-inherit, tls-1-2-strict, tls-1-0-with-1-3, tls-1-2-fs-with-1-3, tls-1-2-fs, and hybrid-policy-1-0. For more information, see TLS Security Policy. |
Application Scenarios
You are advised to configure HTTPS encryption for your load balancers to ensure secure data transmission. ELB allows you to use common TLS security policies to secure your data.
You can use later TLS versions for applications that require enhanced security, and earlier TLS versions for applications that need wider compatibility.
Rule Logic
- If a specified security policy is not configured for the HTTPS listener of a load balancer, this load balancer is non-compliant.
- If a specified security policy is configured for the HTTPS listener of a load balancer, this load balancer is compliant.
