VPC Endpoint Check for Specified Services
Rule Details
Parameter |
Description |
Rule Name |
vpcep-endpoint-enabled |
Identifier |
Description |
If no VPC endpoint is created for a specified service, the check result is non-compliant. |
Tag |
vpcep |
Trigger Type |
Periodic |
Filter Type |
Account |
Rule Parameters |
serviceName: specified service name |
Application Scenarios
VPC Endpoint provides secure, private channels to connect your VPCs to VPC endpoint services, including cloud services or your private services. It allows you to plan networks flexibly without having to use EIPs. What Is VPC Endpoint?
Accessing cloud services through VPC Endpoint protects cloud resources from the public network, reducing data leakage and attack risks.
Solution
Buy a VPC Endpoint as instructed in Buying a VPC Endpoint.
For example, if the rule parameter is swr, the service name of the VPC endpoint you need to buy is com.myhuaweicloud.{region_id}.swr.
Rule Logic
- If no VPC endpoint is created for the specified service, the check result is non-compliant.
- If a VPC endpoint is created for the specified service, the check result is compliant.
