MRS Clusters Should Not Use EIPs
Rule Details
Parameter |
Description |
Rule Name |
mrs-cluster-no-public-ip |
Identifier |
MRS Clusters Should Not Use EIPs |
Description |
If an MRS cluster has an EIP bound, this cluster is non-compliant. |
Tag |
mrs |
Trigger Type |
Configuration change |
Filter Type |
mrs.mrs |
Rule Parameters |
None |
Application Scenarios
Do not attach EIPs to your MRS clusters unless they must communicate over the public network. This reduces the attack surface and the risk of sensitive data leakage.
Solution
Detach EIPs from the Managers of your clusters by following the instructions provided in How Do I Unbind an EIP from FusionInsight Manager of an MRS Cluster?
Rule Logic
- If an MRS cluster has an EIP bound, this cluster is non-compliant.
- If an MRS cluster does not have EIP bound, this cluster is compliant.
