MRS Clusters Are in Specified VPCs
Rule Details
Parameter |
Description |
Rule Name |
mrs-cluster-in-vpc |
Identifier |
Description |
If an MRS cluster is not in the specified VPC, this cluster is noncompliant. |
Tag |
mrs |
Trigger Type |
Configuration change |
Filter Type |
mrs.mrs |
Configure Rule Parameters |
vpcId: VPC ID of an MRS cluster |
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your MRS clusters. For more details, see What Is Virtual Private Cloud?
Solution
You cannot change the VPC of an MRS cluster. Exercise caution when selecting a VPC when creating resources. However, changing VPC subnets is supported. For details, see Changing the VPC Subnet of an MRS Cluster.
Rule Logic
- If an MRS cluster is not in the specified VPC, this cluster is noncompliant.
- If an MRS cluster is in the specified VPC, this cluster is compliant.
