Policy
A policy is a logical expression used to evaluate resource compliance.
A policy cannot work on its own. Instead, you need to attach a policy to a rule.
A policy can be a JSON expression. Table 1 lists policy (JSON expression) parameters.
Parameter |
Description |
Remarks |
id |
Policy ID |
N/A |
name |
Policy name |
You can set a name of up to 64 characters. |
display_name |
Display name of a policy |
A policy display name can contain up to 64 characters. |
description |
Policy description |
Policy description can contain up to 512 characters. |
parameters |
Policy parameters The following attributes are used to describe each policy parameter:
The parameter names, such as name and description contained in the compliance policy remain unchanged.
keywords |
Policy keywords |
Generally, the name abbreviation of the related product is used as a keyword. |
policy_type |
Policy type The options are as follows:
policy_rule_type |
Policy syntax |
Domain Specific Language (DSL): provided by Config to write policy expressions. |
trigger_type |
Trigger type. The options are as follows:
default_resource_types |
Resource type |
Most policies only apply to a limited scope of resources. You are advised to use a rule to only evaluate resource types in default_resource_types. |
The following is an example policy used to check whether specified images are used for ECSs.
"id": "5fa265c0aa1e6afc05a0ff07",
"name": "allowed-images-by-id",
"description": "An ECS image is non-compliant if its ID is not within the specific image ID range.",
"parameters": {
"listOfAllowedImages": {
"name": "null",
"description": "The list of allowed image IDs",
"type": "Array"
"allowed_values": null,
"default_value": null,
"keywords": [
"ecs",
"ims"
"policy_type": "builtin",
"policy_rule_type": "dsl",
"trigger_type": "resource",
"policy_rule": {
"allOf": [
"value": "${resource().provider}",
"comparator": "equals",
"pattern": "ecs"
"value": "${resource().type}",
"pattern": "cloudservers"
"value": "${resource().properties.metadata.meteringImageId}",
"comparator": "notIn",
"pattern": "${parameters('listOfAllowedImages')}"
For more examples, see Example Custom Rules.
