Viewing Resource Conformance Data
Config provides you with rules to evaluate resources. You can view compliance data of the resources evaluated in the Resource Overview page.
- Click
in the upper left corner of the page. Under Management & Governance, select Config. - On the Resource List page, click the name of a target resource.
- The Resource Conformance tab is displayed by default. The rules applied and the evaluation results are displayed in a list in the Resource Conformance tab.
In the search box above the list, enter a rule name, a rule ID, the trigger type, the time of the latest evaluation, or the evaluation result to filter rules.
- Click a rule name in the rule list to see rule details.
Figure 1 Viewing resource conformance data
