Filtering Resources
You can filter resources by service, resource type, and region on the Resource List page. In the search box in the middle of the page, you can also enter more specific resource information to quickly search for resources.
This section describes how to quickly search for your resources.
Supported Filter Criteria
Filter Criteria |
Description |
Name |
Resource name. Fuzzy search is supported. The resource name is case-insensitive. |
Resource ID |
Resource ID. Fuzzy search is supported. The resource ID is case-sensitive. |
Resource Status |
Resource status. A resource can be in either of the following states:
Tags |
You can select a tag key and one or all values of this key to filter resources. |
Enterprise Project |
The enterprise project which resources belong to. If you select an enterprise project, resources in this enterprise project will be displayed.
To filter resources by enterprise project, you need to enable Enterprise Center first. Filtering resources by enterprise project is only available to some users. |
- Click
in the upper left corner of the page. Under Management & Governance, select Config. - On the Resource List page, filter resources by resource name, resource ID, resource status, enterprise project, or resource tag.
Figure 1 Filtering resources
