- What's New
- Function Overview
Product Bulletin
- Vulnerability Notice
Product Notices
- [Product Discontinuation Notice] RDS for PostgreSQL 12 Will Be Discontinued on May 1, 2025, 00:00:00 GMT+08:00
- [Offline Notice] RDS for PostgreSQL 10 and 11 Will Go Offline on November 1, 2024, 00:00:00 GMT+08:00
- [Product Discontinuation Notice] RDS for MySQL 5.6 Will Be Discontinued on July 1, 2024, 00:00:00 GMT+08:00
- [Product Discontinuation Notice] RDS for PostgreSQL 10 and 11 Will Be Discontinued on July 1, 2024, 00:00:00 GMT+08:00
- [Offline Notice] RDS for PostgreSQL 9.5 and 9.6 Will Go Offline on July 1, 2024, 00:00:00 GMT+08:00
- [Notice] OBT for Memory Acceleration of RDS for MySQL Starts from May 28, 2024
- Product Release Notes
- Billing
Getting Started
- Getting Started with RDS for MySQL
- Getting Started with RDS for MariaDB
- Getting Started with RDS for PostgreSQL
- Getting Started with RDS for SQL Server
- Kernels
User Guide
Working with RDS for MySQL
- Using IAM to Grant Access to RDS
- Buying an RDS for MySQL DB Instance
- Instance Connection
- Database Usage
- Database Migration
- Version Upgrade
- Instance Management
Instance Modifications
- Changing a DB Instance Name
- Changing a DB Instance Description
- Changing the Replication Mode
- Changing the Failover Priority
- Changing Read/Write Permissions
- Enabling or Disabling Event Scheduler
- Changing a DB Instance Class
- Changing a Storage Type
- Scaling Up Storage Space
- Configuring Storage Autoscaling
- Changing the Maintenance Window
- Changing a DB Instance Type from Single to Primary/Standby
- Promoting a Read Replica to Primary
- Manually Switching Between Primary and Standby DB Instances
- Changing the AZ of a Standby DB Instance
- Updating the OS of a DB Instance
- Data Backups
- Data Restorations
- Read Replicas
Database Proxy (Read/Write Splitting)
- Introduction to RDS for MySQL Database Proxy
- Constraints on Database Proxy
- Using RDS for MySQL Database Proxies for Read/Write Splitting
Database Proxy Configurations
- Configuring Transaction Splitting
- Configuring Connection Pools
- Modifying Read/Write Splitting Parameters
- Configuring the Delay Threshold and Routing Policy
- Enabling or Disabling Access Control
- Changing the Read/Write Splitting Address
- Applying for and Changing a Private Domain Name for a Database Proxy
- Changing the Read/Write Splitting Port
- Changing the Number of Proxy Nodes
- Changing the Instance Class of a DB Proxy Instance
- Configuring Multi-Statement Processing Modes
- Changing a Proxy from Pay-per-Use to Yearly/Monthly
- Database Proxy Lifecycle
- Database Proxy Kernel Versions
- Best Practices for Database Proxy
- Problem Diagnosis and SQL Analysis
Security and Encryption
- Database Account Security
- Resetting the Administrator Password to Restore Root Access
- Changing a Security Group
- Performing a Server-Side Encryption
- Configuring an SSL Connection
- Configuring the TDE Function
- Configuring a Password Expiration Policy
- Unbinding an EIP
- Using the Database of the Latest Version
- Using DBSS (Recommended)
- Parameters
- Log Management
- Metrics and Alarms
- Billing Management
- Interconnection with CTS
- Task Center
- RDS for MySQL Tags
- RDS for MySQL Quotas
- MySQL Memory Acceleration
Working with RDS for MariaDB
- Suggestions on Using RDS for MariaDB
Performance Tuning
- What Is the Maximum Number of IOPS Supported by RDS?
- How Do I Improve the Query Speed of My RDS Database?
- Identifying Why CPU Usage of RDS for MariaDB Instances Is High and Providing Solutions
- RDS for MariaDB Memory Usage Too High
- What Should I Do If an RDS DB Instance Is Abnormal Due to Full Storage Space?
- Troubleshooting Slow SQL Issues for RDS for MariaDB Instances
- Resolving Insufficient Storage Issues for RDS for MariaDB Instances
- Permissions Management
- Instance Lifecycle
- Upgrading a Minor Version
- Storage Autoscaling
- Read Replicas
- Data Backups
- Data Restorations
Parameter Templates
- Creating a Parameter Template
- Modifying RDS for MariaDB Instance Parameters
- Exporting a Parameter Template
- Importing a Parameter Template
- Comparing Parameter Templates
- Viewing Parameter Change History
- Replicating a Parameter Template
- Resetting a Parameter Template
- Applying a Parameter Template
- Viewing Application Records of a Parameter Template
- Modifying a Parameter Template Description
- Deleting a Parameter Template
- Connection Management
- Database Management
- Account Management (Non-Administrator)
- Account and Network Security
- Log Management
DBA Assistant
- Function Overview
- Viewing the Overall Status of a DB Instance
- Managing Real-Time Sessions
- Viewing Performance Metrics
- Subscribing to Intelligent O&M
- Viewing Storage Usage
- Viewing Table Diagnosis Results
- Setting a Diagnosis Threshold
- Viewing Top Databases and Tables by Physical File Size
- Viewing Slow Query Logs
- Concurrency Control
- Auto Flow Control
- Managing Diagnosis Reports
- Task Center
- Managing Tags
- Managing Quotas
Working with RDS for PostgreSQL
- Buying an RDS for PostgreSQL DB Instance
Instance Connection
- Overview
- Connecting to an RDS for PostgreSQL Instance Through DAS (Recommended)
- Connecting to an RDS for PostgreSQL Instance Through the psql CLI Client
- Connecting to an RDS for PostgreSQL Instance Using pgAdmin
- Connecting to an RDS for PostgreSQL Instance Through JDBC
- Connecting to an RDS for PostgreSQL Instance Using Python
- Database Usage
- Version Upgrade
- Changing the Storage Type
- Scaling Storage Space
- Data Backups
- Data Restorations
- Read Replicas
- DR Management
- Extension Management
- Function Overview
- Performance Monitoring
- Problem Diagnosis
- SQL Analysis
Common Performance Problems
- Troubleshooting High CPU Usage
- Troubleshooting High Memory Usage
- Troubleshooting Database Age Increase Problem
- Troubleshooting High Storage Space Usage
- Troubleshooting Abnormal Connections and Active Connections
- Troubleshooting Long-Running Transactions
- Troubleshooting Inactive Logical Replication Slots
- Troubleshooting High Oldest Replication Slot Lag or Replication Lag
- Troubleshooting SQL Statements That Have Been Executed for 3s or 5s
- Security and Encryption
Parameters
- Modifying Parameters of an RDS for PostgreSQL Instance
Managing Parameter Templates
- Suggestions on RDS for PostgreSQL Parameter Tuning
- Log Management
- Task Center
- RDS for PostgreSQL Tags
- RDS for PostgreSQL Quotas
- RDS for PostgreSQL Enhanced Edition
Working with RDS for SQL Server
- Suggestions on Using RDS for SQL Server
- Performance Tuning
- Cloning a DB Instance
- Configuring Autoscaling
- Updating the DB Engine and OS of a DB Instance
- Read Replicas
- Data Backups
- Data Restorations
Parameters
- Modifying RDS for SQL Server Instance Parameters
- Accounts (Non-Administrator)
- Databases
- Distributed Transactions
- SQL Server Integration Services (SSIS)
- Log Management
- DBA Assistant
- Publications and Subscriptions
- Task Center
- Enabling or Disabling FileStream
- CLR Integration
- Default Language Setting for RDS for SQL Server
Usage of Stored Procedures
- Creating a Database Account
- Granting SSIS Permissions to a Domain Account
- Deploying an SSIS Project
- Changing Custom Database Names
- Viewing Error Logs
- Tracing Flags
- Capturing Change Data
- Removing a Custom Database from an Availability Group
- Replicating Databases
- Granting Database Permissions to Subaccounts
- Deleting Custom Databases
- Updating Database Statistics
- Cycling SQL Server Agent Error Logs
- Cycling SQL Server Error Logs
- Creating Alerts
- Setting Up Notifications for Alert
- Creating Operators for Alerts and Jobs
- Updating Alert Settings
- Updating Alert Notification Methods
- Updating Information About Operators for Alerts and Jobs
- Removing Alerts
- Removing SQL Server Agent Notification Definitions for Specific Alerts and Operators
- Removing Operators
- Shrinking Databases
- Changing the Permission to View All Databases
- Granting Permissions of Database-Level db_owner Role
- RDS for SQL Server Tags
- RDS for SQL Server Quotas
Best Practices
- Overview
RDS for MySQL
- Migrating Data from Self-Managed MySQL Databases to RDS for MySQL
- Configuring Remote Single-Active DR for an RDS for MySQL Instance Using DRS
- Migrating MySQL Databases from Other Clouds to RDS for MySQL
- Using RDS for MySQL to Set Up WordPress
- Using RDS for MySQL to Set Up Discuz!
- Description of innodb_flush_log_at_trx_commit and sync_binlog
- How Do I Improve the Query Speed of My RDS for MySQL Instance?
- Handling RDS for MySQL Long Transactions
- Security Best Practices
RDS for PostgreSQL
Creating a Cross-Region DR Relationship for an RDS for PostgreSQL Instance
- Overview
- Resource Planning
- Operation Process
- Preparing an RDS for PostgreSQL Instance in the Production Center
- Preparing an RDS for PostgreSQL Instance in the DR Center
- Configuring Cross-Region Network Connectivity
- Creating a DR Relationship
- Promoting a DR Instance to Primary
- Removing a DR Relationship
- FAQs
- RDS for PostgreSQL Publications and Subscriptions
- User-Defined Data Type Conversion
- Using Client Drivers to Implement Failover and Read/Write Splitting
- Using PoWA
- Best Practices for Using pg_dump
- Best Practices for Using PgBouncer
RDS for SQL Server
- Restoring Data from Backup Files to RDS for SQL Server DB Instances
- Migrating Data from a Self-Managed SQL Server Database on an ECS to an RDS for SQL Server DB Instance
- Modifying Parameters of RDS for SQL Server Instances
- Supporting DMVs
- Using the Import and Export Function to Migrate Data from a Local Database to an RDS for SQL Server DB Instance
- Creating a Subaccount of rdsuser
- Creating tempdb Files
- Microsoft SQL Server Publication and Subscription
- Installing a C# CLR Assembly in RDS for SQL Server
- Creating a Linked Server for an RDS for SQL Server DB Instance
- Deploying SQL Server Reporting Services (SSRS) on RDS for SQL Server
- Shrinking an RDS for SQL Server Database
- Using DAS to Create and Configure Agent Job and DBLink on the Master and Slave Databases for RDS for SQL Server Instances
- Creating a Job for Scheduled Instance Maintenance
- Using Extended Events
- Performance White Paper
API Reference
- Before You Start
- API Overview
- Calling APIs
API v3.1 (Recommended)
- Modifying Parameters of a Specified Instance
- Restoring Data to an Existing DB Instance
- Restoring Tables to a Specified Point in Time (RDS for MySQL)
- Querying Database Error Logs (MySQL)
- Querying Database Slow Logs (MySQL)
- Deleting a Database (RDS for SQL Server)
- Shrinking Database Logs
API v3 (Recommended)
- Querying Version Information About APIs
- Querying Version Information About a DB Engine
- Querying Database Specifications
- Querying the Storage Type of a Database
- Querying Storage Usage of a DB Instance
DB Instance Management
- Creating a DB Instance
- Creating a DB Instance (API v5)
- Changing the Billing Mode from Pay-per-Use to Yearly/Monthly
- Stopping an Instance
- Starting an Instance
- Changing the Description of a DB Instance
- Applying for a Private Domain Name
- Modifying a Private Domain Name
- Querying the Domain Name of a DB Instance
- Querying the IPv6 Domain Name of a DB Instance
- Obtaining the Replication Status of a DB Instance
- Querying Available Instance Classes for a DB Instance
- Changing DB Instance Specifications
- Scaling Up Storage Space of a DB Instance
- Configuring an Autoscaling Policy
- Querying an Autoscaling Policy
- Changing a Single DB Instance to Primary/Standby DB Instances
- Rebooting a DB Instance
- Deleting a DB Instance
- Querying DB Instances
- Binding and Unbinding an EIP
- Manually Switching Primary/Standby DB Instances
- Changing the Data Replication Mode of Primary/Standby DB Instances
- Migrating a Standby DB Instance
- Configuring the Maintenance Window
- Upgrading the Minor Version of a DB Instance
- Configuring a Monitoring by Seconds Policy
- Querying a Monitoring by Seconds Policy
- Enabling TDE for a DB Instance (RDS for SQL Server)
- Querying TDE Status of a DB Instance (RDS for SQL Server)
- Unlocking a DB Instance from the Read-Only State
- DR Instances
- Database Security
Backup and Restoration
- Setting an Automated Backup Policy
- Setting a Cross-Region Backup Policy
- Obtaining an Automated Backup Policy
- Querying Information About a Cross-Region Backup Policy
- Creating a Manual Backup
- Obtaining Backups
- Querying Cross-Region Backups
- Querying DB Instances for Which Cross-Region Backups Are Created
- Obtaining the Link for Downloading a Backup File
- Deleting a Manual Backup
- Querying the Restoration Time Range
- Querying the Restoration Time Range of a Cross-Region Backup
- Restoring Data to a New DB Instance
- Stopping a Backup (RDS for PostgreSQL)
- Checking Whether Fast Restoration Can Be Used for Restoring Databases or Tables (RDS for MySQL)
- Querying Tables That Can Be Restored to a Specified Point in Time (RDS for PostgreSQL)
- Querying Databases That Can Be Restored to a Specified Point in Time
- Restoring Tables to a Specified Point in Time (RDS for PostgreSQL)
- Restoring Databases to a Specified Point in Time
Upgrading a Major Version
- Querying the Target Version to Which a DB Instance Can Be Upgraded (RDS for PostgreSQL)
- Performing a Major Version Upgrade Pre-Check for a DB Instance (RDS for PostgreSQL)
- Querying the Major Version Check Status or Upgrade Status of a DB Instance (RDS for PostgreSQL)
- Querying the Major Version Upgrade Check History of a DB Instance (RDS for PostgreSQL)
- Upgrading a Major Version of a DB Instance (RDS for PostgreSQL)
- Querying the Major Version Upgrade History of a DB Instance (RDS for PostgreSQL)
Log Information Queries
- Showing Original Logs
- Querying Slow Query Log Files (SQL Server)
- Querying Extended Logs (RDS for SQL Server)
- Obtaining Links for Downloading Extended Logs (RDS for SQL Server)
- Obtaining Slow Query Log Statistics (RDS for MySQL)
- Obtaining Links for Downloading Slow Query Logs
- Obtaining Links for Downloading Error Logs (RDS for PostgreSQL)
- Setting SQL Audit
- Querying the Policy for SQL Audit Logs
- Obtaining Audit Logs
- Obtaining the Links for Downloading Audit Logs
- Setting the Local Retention Period of Binlogs
- Obtaining the Local Retention Period of Binlogs
- Instance Diagnosis
SQL Statement Concurrency Control (RDS for PostgreSQL)
- Adding a SQL Statement Concurrency Control Rule for a Database
- Deleting a SQL Statement Concurrency Control Rule
- Modifying a SQL Statement Concurrency Control Rule
- Querying SQL Statement Concurrency Control Rules
- Enabling or Disabling a SQL Statement Concurrency Control Rule or Disabling All SQL Statement Concurrency Control Rules
- Database Proxy (RDS for MySQL)
Database and Account Management (MySQL)
- Precautions
- Querying Details About a Database (Discarded)
- Querying Authorized Databases of a Specified User
- Modifying the Database Remarks of a Specified DB Instance
- Querying Database Users of a DB Instance (Discarded)
- Querying Authorized Users of a Specified Database
- Modifying Remarks of a Database Account
- Deleting a Database Account
- Configuring a Password for a Database Account
- Authorizing a Database Account
- Revoking Permissions of a Database Account
- Resetting the Password for User root
Database and Account Management (PostgreSQL)
- Creating a Database Schema
- Granting Read or Write Permissions to a Database Account
- Resetting a Password for a Database Account
- Querying Database Schemas
- Configuring Account Permissions
- Changing the Database Owner
- Granting a Role to a User
- Revoking a Role from a User
- Querying Roles
- Querying pg_hba.conf of a DB Instance
- Modifying or Adding One or More Records in pg_hba.conf
- Overwriting pg_hba.conf
- Deleting One or More Records from pg_hba.conf
- Querying the pg_hba.conf Change History of a DB Instance
Database and Account Management (Microsoft SQL Server)
- Querying the Available SQL Server Character Set
- Adding Host Addresses for MSDTC
- Querying MSDTC Hosts
Parameter Management
- Obtaining a Parameter Template List
- Querying Change History of Instance Parameters
- Obtaining the Parameter Template of a Specified DB Instance
- Obtaining Parameters in a Specified Parameter Template
- Extension Management (RDS for PostgreSQL)
- Configuring Replication Delay for a Read Replica (RDS for PostgreSQL)
- Recycling a DB Instance
- Tag Management
- Quota Management
- Obtaining Task Information
Historical APIs
API v3
- Querying API Versions
- Modifying Parameters of a Specified DB Instance
- Querying Database Slow Logs (RDS for MySQL)
- Shrinking Database Logs (Not Recommended)
- Database Proxy (PostgreSQL)
API v3
- Appendix
- Change History
- SDK Reference
Product Consulting
- What Should I Pay Attention to When Using RDS?
- Will My RDS DB Instances Be Affected by Other User Instances?
- Will Different RDS DB Instances Share CPU and Memory Resources?
- How Long Does It Take to Create an RDS DB Instance?
- What Can I Do About Slow Responses of Websites When They Use RDS?
- What Is the Time Delay for Primary/Standby Replication?
- Can Multiple ECSs Connect to the Same RDS DB Instance?
- Will Backups Be Encrypted After Disk Encryption Is Enabled for My RDS Instance?
- What Is the Availability of RDS DB Instances?
- Does RDS Support Cross-AZ High Availability?
- Can RDS Primary/Standby DB Instances Be Changed to Single DB Instances?
- What Are the Differences Between RDS for MySQL and TaurusDB?
- Does RDS Support CloudPond?
- What Encryption Functions Does RDS for MySQL Support?
- Is RDS for MySQL Compatible with MariaDB?
- Does RDS for MySQL Support TokuDB?
- What Are the Restrictions on RDS for MySQL Instances After GTID Is Enabled?
- What Is the Maximum Size Allowed for a Single Table in RDS for MySQL Instances?
- What Are the Differences Between RDS and Other Database Solutions?
- Can I Use a Template to Create DB Instances?
- What Can I Do If I Can't Find My RDS Resources?
- Resource Freezing, Release, Stopping, Deletion, and Unsubscription
Resource and Disk Management
- Which Types of Logs and Files Occupy RDS Storage Space?
- Does RDS Support Storage Scale-Down of DB Instances?
- Which Items Occupy the Storage Space of My RDS DB Instances?
- How Much Storage Space Is Required for DDL Operations?
- What Are the Differences Between the Storage Space and Backup Space of an RDS for PostgreSQL Primary/Standby Instance?
- How Do I Prevent a Sharp Increase in Data Disk Usage If I Want to Push a Large Amount of Data to My RDS for SQL Server Instance in a Short Period of Time?
Database Connection
- What Should I Do If I Can't Connect to My RDS DB Instance?
- What Do I Do If the Number of RDS Database Connections Reaches the Upper Limit?
- What Is the Maximum Number of Connections to an RDS DB Instance?
- What Should I Do If an ECS Cannot Connect to an RDS DB Instance Through a Private Network?
- What Should I Do If My RDS Instance Fails to Be Connected Due to Database Client Problems?
- What Should I Do If an RDS Database Problem Causes a Connection Failure?
- Do Applications Need to Support Reconnecting to an RDS DB Instance Automatically?
- Why Can't I Ping My EIP After It Is Bound to an RDS DB Instance?
- Can I Access an RDS DB Instance Over an Intranet Connection Across Regions?
- Why Did the New Password Not Take Effect After I Reset the Administrator Password of My RDS Instance?
- Can I Access Standby RDS DB Instances?
- How Do I Check the Connections to an RDS for MySQL Instance?
- Will I Be Logged Out If the Connection to RDS for SQL Server Instances Times Out?
- What Should I Do If an RDS for SQL Server DB Instance Failed to Be Connected?
- Can an External Server Access the RDS Database?
- Will My Access Be Restricted by Bandwidth When I Connect to My Instance from an ECS over a Private Network?
- How Can I Install SQL Server Management Studio?
Database Migration
- What Types of DB Engines Does RDS Support for Importing Data?
- Why Do I Need to Use the mysqldump or pg_dump Tools for Migration?
- What Should I Do When a Large Number of Binlog Files Cause Storage Space Insufficiency During an RDS MySQL Instance Migration?
- Precautions for Exporting Large Tables Through mysqldump
- Commands for Exporting Data Through mysqldump
Database Permission
- Why Does the Root User of My RDS Instance Not Have the Super Permissions?
- What Are the Differences Between RDS ManageAccess and DAS Permissions?
- How Do I View Authorized Databases After a Local Client Is Connected to an RDS DB Instance?
- Can Multiple Users Log In to an RDS Instance Through DAS at the Same Time? Will the Accounts Be Locked If I Enter Wrong Passwords Several Times in a Row?
- Does RDS for MySQL Support Multiple Accounts?
- Why Did I Fail to Create an Object on the postgres Database as a Common User?
- What Should I Do If a Role Failed to Be Deleted from an RDS for PostgreSQL Instance?
- Why Did My RDS for PostgreSQL Migration Fail?
- How Do I Grant the REPLICATION Permission to an RDS for PostgreSQL Database User?
- Why Is An Error Reported When I Attempt to Change a Table Owner of My RDS for PostgreSQL Instance?
- How Are the Login Name Permissions of RDS for SQL Server 2017 Enterprise Edition Primary/Standby DB Instances Synchronized to Its Read Replicas?
- After a Primary Instance Account Is Deleted and Recreated on RDS for SQL Server, Will the Permissions Be Automatically Synchronized?
Database Storage
- What Types of Storage Does RDS Use?
- How Do I View the Storage Usage of My RDS Instance?
- What Storage Engines Does RDS for MySQL Support?
- Does RDS for MySQL Support Stored Procedures and Functions?
- What Should I Do If My Data Exceeds the Available Storage of an RDS for MySQL Instance?
- Where Are the Database Files Created on My RDS for SQL Server Instance Stored?
Database Usage
- How Do I Use DAS to Query SQL Statements?
- How Do I View Session IDs and Login and Logout Time of an RDS Database?
- How Do I Create a Scheduled Task for My RDS for MySQL Instance?
- What Should I Do If the root Account of My RDS for MySQL Instance Was Deleted by Mistake?
- What Should I Do If Garbled Characters Are Displayed After SQL Query Results Are Exported to an Excel File for My RDS Instance?
- Does the OPTIMIZE TABLE Operation Lock Tables on an RDS DB Instance?
- Does RDS for MySQL 8.0 Support Full-Text Search?
- How Do I Use the mysqlbinlog Tool?
- Why Is an Error Reported When I Attempt to Delete a Database from My RDS for SQL Server Primary/Standby DB Instance?
- How Do I View My Backup Storage Usage?
- How Is RDS Backup Data Billed?
- Why Has Automated Backup of My RDS Instance Failed?
- Why Is Data Lost or Deleted from My RDS Instance?
- How Long Does RDS Store Backup Data For?
- How Do I Clear RDS Backup Space?
- Can My RDS Instance Still Be Used in the Backup Window?
- How Can I Back Up an RDS Database to an ECS?
- Can I Dump RDS Backup Files to My OBS Bucket?
- Does RDS for MySQL Support Table-Level Backup to a Specified OBS Bucket?
- Can I Delete the RDS for MySQL Backup Policy?
- Does RDS for PostgreSQL Support Table PITR?
- How Are Unsynchronized Backups Generated for RDS for SQL Server DB Instances?
- Where Are RDS Backup Files Stored?
Read Replicas and Read/Write Splitting
- Why Can't I Purchase Read Replicas on the RDS Console?
- Can I Change the Replication Mode Between RDS Primary Instances and Read Replicas?
- Does RDS Support Read/Write Splitting?
- Does RDS for MySQL Support Sharding and Read/Write Splitting?
- Can I Request Multiple Read/Write Splitting Addresses for My RDS for MySQL Instance?
- Database Monitoring
Capacity Expansion and Specification Change
- Are My RDS DB Instances Still Available During Storage Scale-up and Instance Class Change?
- Why Does My RDS Instance Become Faulty After Its Database Port Is Changed?
- Can I Change the VPC or Subnet that My RDS DB Instance Belongs To?
- How Do I Distinguish Between General-Purpose and Dedicated RDS for MySQL Instances Using Cloud SSDs?
Database Parameter Modification
- Can I Use SQL Commands to Modify Global Parameters of My RDS Instance?
- How Do I Change the Time Zone of an RDS DB Instance?
- How Do I Set the Encoding Format of the RDS for MySQL 8.0 Character Set?
- How Do I Set Case Sensitivity for RDS for MySQL Table Names?
- How Do I Enable Query Caching for My RDS for MySQL Instance?
- How Do I Configure a Password Expiration Policy for My RDS for MySQL Instance?
- How Do I Change the Transaction Isolation Level of an RDS for MySQL Instance?
- How Do I Ensure that the Character Set of an RDS MySQL Database Is Correct?
- How Do I Use the utf8mb4 Character Set to Store Emojis in an RDS for MySQL DB Instance?
- What Inappropriate Parameter Settings Will Cause Unavailability of My RDS for PostgreSQL Instance?
- How Do I Set the Upper Limit for the Storage Space Occupied by Temporary Files of My RDS for PostgreSQL Instance?
- How Do I Configure the test_decoding Extension for My RDS for PostgreSQL Instance?
- Where Should I Store NDF Files for RDS for SQL Server?
- How Do I Modify the Collation of an RDS for SQL Server Character Set?
- Log Management
Network Security
- How Can Data Security Be Ensured During Transmission When I Access an RDS Instance Through an EIP?
- How Can I Prevent Untrusted Source IP Addresses from Accessing RDS?
- How Do I Import the SSL Certificate of an RDS Instance to a Windows or Linux Server?
- How Do I Check the Validity Period of the SSL Certificate of My RDS for MySQL Instance?
- What Are the Possible Causes for Data Corruption of an RDS Instance?
- After My RDS DB Instance Is Deleted, Why Can't the Associated Security Group Be Deleted Immediately?
- Version Upgrade
- Developer-Related APIs and SDKs for RDS
Product Consulting
Troubleshooting
RDS for MySQL
Backup and Restoration Issues
- No SUPER Permissions When Restoring an RDS for MySQL Full Backup to a Local MySQL Database
- Backup Failures Due to DDL Operations
- Restoring an On-Premises or Huawei Cloud Backup File to an RDS DB Instance
- RDS for MySQL Backup Job Failure
- Manual Backups Taking More Time Than Automated Full Backups
- Incorrect Login Password During Data Restoration from a Local Backup File
- Automated Incremental Backup Failed Due to Full Storage
- RDS Point-in-Time Restoration Task Failure
- SQL Statements Such as SET @@SESSION.SQL_LOG_BIN Displayed After You Run mysqldump
- Insufficient Permissions During Data Export Using mysqldump
- Key Considered Invalid or Deleted During Table-Level PITR
Primary/Standby Replication Issues
- How Primary/Standby Replication Works
- Automatic Recovery of Extended Primary/Standby Replication Delay
- Primary/Standby Replication Delay Scenarios and Solutions
- Abnormal Replication Between Primary and Standby RDS DB Instances
- Primary/Standby Replication Delay Increases Sharply and Then Decreases
- Insufficient Permissions Reported for Canal
- Canal Fails to Parse Binlogs
- RDS for MySQL Binlog Issues
- Parameter-related Issues
Performance Issues
- High CPU Usage
- Out of Memory (OOM) Errors
- Insufficient Disk Bandwidth
- Slow SQL Statements Due to Improper Composite Index Settings
- DB Instance Becoming Read-Only Due to Insufficient Storage
- High Storage Usage Due to Uncleared Old Binlogs
- Slow Response Due to Deadlocks
- Read Replica Uses Far More Storage Than the Primary Instance
- CPU Usage Increase
- Slow SQL Execution Due to Hot and Cold Data Problems
- High Table Fragmentation Rate
- Full Storage Caused by Complex Queries
- Why Is My SQL Query So Slow?
- Instance Class Change or Minor Version Upgrade Failure Caused by Long Transactions
- Native Error 1461 Reported by an RDS for MySQL DB Instance
- System Inaccessible After Field Addition to an RDS for MySQL Database Table
- Storage Filled Up by Undo Logs Due to Long Transactions
- Locating Long Transactions
- Sharp Increase in the Commit Time of Some SQL Statements
- Oversized ibdata1
SQL Issues
- Double Quotation Marks Cannot Be Identified During SQL Statement Execution
- Error 1366 Reported When Data Containing Emojis Is Updated
- Failed to Change the varchar Length Due to the Index Length Limit
- Invalid TIMESTAMP Default Value during Table Creation
- AUTO_INCREMENT Not Displayed in the Table Structure
- Slow Stored Procedure Execution Due to Inconsistent Collations
- ERROR [1412] Reported for a DB Instance
- Error Message "Too many keys specified" Displayed When a Secondary Index Is Created
- Failed to Delete a Table with a Foreign Key
- DISTINCT and GROUP BY Optimization
- Character Set and Collation Settings
- An Error Message Is Displayed When a User Is Created for a DB Instance
- Slow SQL Queries After a Large Amount of Data Is Deleted from a Large Table
- Event Scheduler Not Taking Effect Immediately After Being Enabled
- Equivalent Comparison Failures with Floating-Point Numbers
- A Large Number of SELECT Requests Routed to The Primary Instance After Database Proxy Is Enabled
- RENAME USER Execution Failure
- ERROR[1451] Reported When a Table with Foreign Keys Cannot Be Deleted
- Solution to the Failure of Converting the Field Type
- "Row size too large" Reported When an RDS for MySQL Table Failed to Be Created
- ERROR [1412] Reported by an RDS for MySQL DB Instance
- Instance Reboot Failure or ERROR 1146: Table 'xxx' doesn't exist Reported During Table Operations
- Error Reported During Pagination Query
- Error Reported During User Creation
- Syntax Error Reported When GRANT Is Used to Grant All Privileges
- Error Reported During Table Creation for an RDS for MySQL 5.6 DB Instance
- Inconsistent Data Obtained on the Primary and Standby Nodes When a Query Is Performed Using an Auto-Increment Primary Key Value
- "Data too long for column" Displayed When Data Is Inserted into an RDS for MySQL Instance
Connection Issues
- "Access denied" Displayed During Database Connection
- Failed to Connect to a Database Using mariadb-connector in SSL Mode
- Error Message "connection established slowly"
- Login Failed After ssl_type of root Is Changed to ANY
- Error Reported During Login to a DB Instance Through DAS
- "Your password does not satisfy the current policy requirements" Displayed When Permissions Are Granted or Revoked on DAS
- SSL Connection Failed Due to Inconsistent TLS Versions
- Failed to Connect to a Database as root
- RDS for MySQL Client Automatically Disconnected from a DB Instance
- RDS for MySQL DB Instance Inaccessible
- Login Failed After the authentication_string Field Is Changed to Display the Password for RDS for MySQL
- MySQL-server Connection Failure After a Version Upgrade of RDS for MySQL
- Connection Exit Due to Improper Timeout Parameter Settings
- Database Connection Through Code (php/java/python) Failed After SSL Is Enabled
- There Is a Disconnection Every 45 Days Due to the istio-citadel Certificate System
- Error 1251 Reported During Login to a DB Instance on the Navicat Client After the Database Version Is Upgraded
Other Issues
- No Scanned Rows Recorded in Slow Query Logs
- Rows Recorded in the SQL Diagnosis Result Far Less Than the Scanned Rows Recorded in Slow Query Logs
- Millisecond-Level SQL Statements Recorded in Slow Query Logs
- Viewing Storage of RDS DB Instances
- "The table is full" Displayed in Error Logs
- Audit Log Upload Policy Description
- Auto-increment Field Values
- Starting Value and Increment of AUTO_INCREMENT
- AUTO_INCREMENT Value Exceeding the Maximum Value of This Field plus 1
- Auto-Increment Field Value Jump
- Changing the AUTO_INCREMENT Value of a Table
- Failed to Insert Data Because Values for the Auto-increment Primary Key Field Reach the Upper Limit
- The Impact of Creating an Empty Username
- Connection to a Primary/Standby DB Instance Suspended Using pt-osc
- Error Reported During Payment for a DB Instance
- Failed to Change a Database Name
- Error Reported When a DB Instance Is Purchased
RDS for PostgreSQL
- A Large Number of Schemas Whose Owner Is rdsadmin
- Index Name Containing a Schema Name During Index Creation
- Authentication Not Supported When a DB Instance Is Accessed Through an Application
- Error Reported When a Request Is Executed Through an Existing Connection
- Slow Instance Reboot Due to Too Many Inodes
- "password is easily cracked" Displayed When an RDS for PostgreSQL User Is Created
RDS for SQL Server
- Account Creation Failure for a SQL Server Database Migrated from Alibaba Cloud to Huawei Cloud
- Error Reported When a New Account Is Used to Log In to an RDS for SQL Server Instance
- Failed to Change the Instance Class of an RDS for SQL Server Instance or Perform a Primary/Standby Switchover
- How Do I Remove and Re-establish a Replication of My RDS for SQL Server Instance?
RDS for MySQL
- Videos
- Glossary
More Documents
- Introduction
- Data Migration
- Instance Modifications
- Read Replicas
Backups and Restorations
- Working with Backups
- Configuring an Intra-Region Backup Policy
- Downloading a Backup File
- Downloading a Binlog Backup File
- Setting a Local Retention Period for MySQL Binlogs
- Restoring from Backup Files to RDS for MySQL
- Restoring a DB Instance to a Point in Time
- Restoring a Table to a Specified Point in Time
- Replicating a Backup
Parameter Template Management
- Suggestions on Tuning MySQL Parameters
- Data Security
- Metrics
- Log Management
- Task Center
- Managing Tags
- Data Migration
- PostgreSQL Enhanced Edition
- Read Replicas
- Backups and Restorations
- Data Security
- Metrics
- Log Management
- Task Center
- Plugin Management
- Managing Tags
- Read Replicas
- Data Security
- Metrics
- Log Management
- Task Center
- Usage of Stored Procedures
- Managing Tags
Product Consulting
- What Precautions Should Be Taken When Using RDS?
- Will My RDS DB Instances Be Affected by Other Users' DB Instances?
- What Should I Do If Garbled Characters Are Displayed After SQL Query Results Are Exported to an Excel File?
- What Can I Do About Websites Responding Slower After Using RDS?
- How Does a Cloud Database Perform a Primary/Standby Switchover?
- Why an Error is Reported When I Attempt to Delete a Database from RDS SQL Server Primary/Standby DB Instances?
- Can Primary and Standby RDS DB Instances Be Deployed in the Same AZ?
- What Overhead Does the Storage Space Have After I Applied for an RDS DB Instance?
- How Many DB Instances Can Run on RDS?
- How Many Databases Can Run on an RDS DB Instance?
Database Connection
- How Do I Troubleshoot If the Number of RDS Database Connections Reaches the Upper Limit?
- How Can I Create and Connect to an ECS?
- What Should I Do If an ECS Cannot Connect to an RDS DB Instance?
- What Should I Do If a Database Client Problem Causes a Connection Failure?
- How Do My Applications Access an RDS DB Instance in a VPC?
- Do Applications Need to Support Reconnecting to the RDS DB Instance Automatically?
- How Can I Connect to a PostgreSQL Database Through JDBC?
- Can I Access an RDS DB Instance Over an Intranet Across Regions?
- Is an SSL Connection to a DB Instance Interrupted After a Primary/Standby Switchover or Failover Occurs?
- Does MySQL Support SSL Connections?
- Why Does the New Password Not Take Effect After I Reset the Administrator Password?
- Database Permission
- Database Storage
- Client Installation
- How Long Does RDS Store Backup Data?
- Can My Database Be Used in the Backup Window?
- How Can I Back Up RDS Databases to an ECS?
- Why Has My Automated Backup Failed?
- What Happens to Database Backups After an RDS DB Instance Is Deleted?
- Will My Backups Be Deleted If I Delete My Cloud Account?
- Why Is a Table or Data Missing from My Database?
- Capacity Expansion and Specification Change
- Database Parameter Modification
- Log Management
Network Security
- What Security Protection Policies Does RDS Have?
- How Can I Ensure the Security of RDS DB Instances in a VPC?
- How Can Data Security Be Ensured During Transmission When I Access RDS Through an EIP?
- How Can I Import the Root Certificate to the Windows or Linux OS?
- How Can I Identify Data Corruption?
Product Consulting
- Before You Start
- API Overview
- Calling APIs
- Obtaining an API Version
- Querying Details About DB Instances
- Resetting a Database Password
- Changing the Data Synchronize Model of Primary/Standby DB Instances
- Database Security
Parameter Configuration
- Obtaining Details About Backups
- Restoring Tables to a Specified Point in Time (MySQL)
- Log Information Queries
- Precautions
- Querying Details About Databases
- Querying Details About Database Users
- Database and Account Management (Microsoft SQL Server)
- Appendix
User Guide (Paris Region)
- Introduction
Instance Management
- Selecting Displayed Items
- Exporting DB Instance Information
- Creating a Same DB Instance
- Deleting a DB Instance or Read Replica
- Read Replicas
- Data Migration
- Data Security
- Log Management
- Task Center
Instance Management
Instance Management
- Read Replicas
- Data Migration
- Data Security
- Log Management
- Task Center
- Plugin Management
Instance Management
Product Consulting
Database Connection
- Database Storage
- Log Management
Network Security
- How Can I Identify the Validity Period of an SSL Root Certificate?
Product Consulting
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
- DB Instance Management
- Restoring Data to an Existing or Original DB Instance
- Tag Management
- Appendix
- Introduction
- Data Migration
- Parameter Tuning
- Scaling up Storage Space
- Promoting a Read Replica Into a Single DB Instance
- Read Replicas
- Configuring an Automated Backup Policy
- Restoring from Backup Files to DB Instances
- Data Security
- Log Management
- Task Center
- Data Migration
- Parameter Tuning
- PostgreSQL Kernel Functions
- Read Replicas
- Set a Cross-Region Backup Policy
- Downloading a Full Backup File
- Downloading an Incremental Backup File
- Restoring from Backup Files to RDS for PostgreSQL
- Modifying Instance Parameters
- Plugin Management
- Data Security
- and AlarmsMetrics and Alarms
- Task Center
- Read Replicas
- Data Security
- Task Center
Product Consulting
- How Do I Create an AD Domain?
- What Can I Do About Slow Respond of Websites When They Use RDS?
- Why Is an Error Reported When I Attempt to Delete a Database from RDS SQL Server Primary/Standby DB Instances?
Database Connection
- Is an SSL Connection to a DB Instance Interrupted After a Primary/Standby Switchover or Failover?
- Why Did the New Password Not Take Effect After I Reset the Administrator Password?
- Database Storage
- Log Management
Network Security
- How Can I Import the Root Certificate to a Windows or Linux OS?
Product Consulting
- Before You Start
- API Overview
- Calling APIs
- Database Security
- Precautions
- Tag Management
- Appendix
User Guide (Ankara Region)
- Introduction
- Parameter Tuning
- Read Replicas
- Restoring a Table to a Point in Time
- Introducing Read/Write Splitting
- Enabling Read/Write Splitting
- Configuring Delay Threshold and Distributing Read Weight
- Upgrading the Kernel Version of Database Proxy
- Disabling Read/Write Splitting
- Rules for Distributing Weights
- Testing Read/Write Splitting Performance
- Data Security
- Log Management
- Task Center
- Parameter Tuning
- Read Replicas
- Plugin Management
- Tablespace Management
- Data Security
- Log Management
- Task Center
Product Consulting
- Can I Change the Replication Mode Between Primary DB Instances and Read Replicas?
- What Are the Restrictions on MySQL DB Instances After GTID Is Enabled?
- What Is the Maximum Size Allowed for a Single Table in MySQL Instances?
- Resource and Disk Management
Database Connection
- How Can I Connect to an RDS for PostgreSQL Database Through JDBC?
- Why Cannot I Ping My EIP After It Is Bound to a DB Instance?
- How Can I Obtain the IP Addreenabled SQL auditss of an Application?
- How Do I Set the Encoding Format of the MySQL 8.0 Character Set?
- What Should I Do If the ECS and RDS Are Deployed in Different VPCs and They Cannot Communicate with Each Other?
- How Do I View All IP Addresses Connected to a Database?
- Database Storage
- Database Usage
- Will Backups Be Retained After My RDS Instance Is Deleted?
- How Do I Restore a Local Database Backup to RDS?
- Can I Dump Backup Files to OBS Buckets?
- What Inappropriate Parameter Settings Cause Unavailability of the RDS for PostgreSQL Database?
- How Can I Change the Time Zone?
- How Do I Configure a Password Expiration Policy for RDS for MySQL DB Instances?
- How Do I Change the RDS Transaction Isolation Level?
- Does RDS for PostgreSQL Support the test_decoding Plugin?
- Can I Use SQL Commands to Modify Global Parameters?
- Can I Enable Query Caching for My RDS for MySQL Instance?
Network Security
- How Do I Configure a Security Group to Enable Access to RDS DB Instances?
- What Are the Possible Causes for Data Corruption?
- Version Upgrade
Product Consulting
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Database Security
- Querying Details About Cross-Region Backups
- Querying Details About DB Instances for Which Cross-Region Backups Are Created
- Precautions
- Querying Details About a Database User
- Resetting the Password for User Root
- Appendix
- Change History
Creating a Read Replica
Read replicas enhance the read capabilities and reduce the load on your DB instances.
You can create read replicas as needed.
Up to five read replicas can be created for a DB instance.
The specifications of a read replica must be at least equal to the specifications of the DB instance. If you want the specifications of a read replica to be smaller than those of the DB instance, contact customer service.
- Click
in the upper left corner and select a region.
- Click
in the upper left corner of the page and choose Databases > Relational Database Service.
- On the Instances page, locate the target DB instance and choose More > Create Read Replica in the Operation column.
- On the displayed page, configure information about the DB instance and click Next.
Figure 1 Basic information
Table 1 Basic information Parameter
Billing Mode
Yearly/monthly billing and pay-per-use billing are supported.
Region
By default, read replicas are in the same region as your DB instance.
DB Engine
Same as the DB engine of your DB instance by default and cannot be changed.
DB Engine Version
Same as the DB engine version of the primary DB instance by default and cannot be changed.
Storage Type
Determines the DB instance read/write speed. The higher the maximum throughput is, the higher the DB instance read/write speed can be.
- Cloud SSD: cloud disks used to decouple storage from compute.
- Extreme SSD: uses the 25GE network and RDMA technology to provide you with up to 1 million random read/write performance per disk and low latency per channel.
If you select DSS for Resource Type, only the storage type that you have selected when buying the DSS service is displayed by default.
AZ
RDS allows you to deploy your DB instance and read replicas in a single AZ or across AZs to improve reliability.
Figure 2 SpecificationsTable 2 Instance specifications Parameter
Instance Class
Refers to the vCPU and memory of a DB instance. Different instance classes have different numbers of database connections and maximum IOPS.
After a DB instance is created, you can change its CPU and memory. For details, see section Changing a DB Instance Class.
DB instances in a DCC only support the general-enhanced instance class.
Storage Space
Contains the system overhead required for inodes, reserved blocks, and database operation.
By default, storage space of a read replica is the same as that of the primary DB instance.
Disk Encryption
- Disable: indicates the encryption function is disabled.
- Enable: indicates the encryption function is enabled. Enabling disk encryption improves security but affects system performance.
Key Name: indicates the tenant key. You can select an existing key or create a new one.
- If you enable disk encryption during instance creation, the disk encryption status and the key cannot be changed later.
- After an RDS DB instance is created, do not disable or delete a key that is currently in use. Otherwise, RDS will be unavailable and data cannot be restored.
- For details about how to create a key, see "Creating a CMK" in Data Encryption Workshop User Guide.
Figure 3 Connectivity and additional optionsTable 4 Additional options Parameter
Enterprise Project
If your account has been associated with an enterprise project, select the target project from the Enterprise Project drop-down list.
For more information about enterprise projects, see Enterprise Management User Guide.
Tag
Optional. Tags help you easily identify and manage your read replicas. A maximum of 20 tags can be added for each read replica.
After a read replica is created, you can view its tag details on the Tags page. For details, see Managing Tags.
Table 5 Yearly/monthly read replicas Parameter
Required Duration
The system will automatically calculate the configuration fee based on the selected required duration. The longer the required duration is, the larger discount you will enjoy.
Auto-renew
- By default, this option is not selected.
- If you select this option, the auto-renew cycle is determined by the selected required duration.
- Confirm specifications.
- If you need to modify your settings, click Previous.
- If you do not need to modify your settings, click Submit for pay-per-use read replicas.
- For yearly/monthly read replicas, click Pay Now.
- After a read replica has been created, you can view and manage it on the Instances page by clicking
on the left of the DB instance to which it belongs.
You can view the detailed progress and result of the task on the Task Center page. For details, see Task Center.
FAQ
Q: Does creating read replicas during peak hours increase the load on my primary instance when my primary instance's CPU usage is high?
A: Yes. When a read replica is created, it synchronizes data from the primary instance, which consumes I/O and CPU resources of the primary instance. To avoid this impact, you can create read replicas during off-peak hours.
Follow-up Operations
