Creating a Parameter Template
You can use database parameter templates to manage DB engine configurations. A database parameter template acts as a container for engine configuration values that can be applied to one or more DB instances.
If you create a DB instance without specifying a custom DB parameter template, a default parameter template is used. This default template contains DB engine defaults and system defaults that are configured based on the engine, compute class, and allocated storage of the instance. Parameters in default parameter templates cannot be modified. You need to create your own parameter template to change parameter settings.
Not all of the DB engine parameters in a custom parameter template can be changed.
If you want to use a custom parameter template, you simply create a parameter template and select it when you create a DB instance or apply it to an existing DB instance following the instructions provided in Applying a Parameter Template.
When you have already created a parameter template and want to include most of the custom parameters and values from that template in a new parameter template, you can replicate that parameter template following the instructions provided in Replicating a Parameter Template.
The following are the key points you should know when using parameters in a parameter template:
- When you change a parameter value in a parameter template that has been applied to a DB instance and save the change, the change takes effect only to the DB instance and does not affect other DB instances.
- The changes to parameter values in a custom parameter template take effect only after you apply the template to DB instances. For details, see Applying a Parameter Template.
- When you change dynamic parameter values in parameter templates in batches and save the changes, the changes will take effect only after you apply the parameter templates to DB instances. When you change static parameter values in parameter templates in batches and save the changes, the changes will take effect for DB instances only after you apply the parameter templates to DB instances and manually reboot the DB instances.
- Improper parameter settings may have unintended consequences, including reduced performance and system instability. Exercise caution when modifying database parameters and you need to back up data before modifying parameters in a parameter template. Before applying parameter template changes to a production DB instance, you should try out these changes on a test DB instance.
RDS does not share parameter template quotas with DDS.
You can create a maximum of 100 parameter templates for RDS DB instances. All RDS DB engines share the parameter template quota.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > Relational Database Service. - On the Parameter Templates page, click Create Parameter Template.
- In the displayed dialog box, configure required information and click OK.
- Select a DB engine for the parameter template.
- Enter a template name that consists of 1 to 64 characters. It can contain only letters (case-sensitive), digits, hyphens (-), underscores (_), and periods (.). Avoid starting the name with Default.
- The description consists of a maximum of 256 characters and cannot contain carriage return characters or the following special characters: >!<"&'= Figure 1 Creating a parameter template
