Deleting an AS_Path List
This section describes how to delete an AS_Path list.
Notes and Constraints
If the route policy that an AS_Path list to be deleted belongs to has been associated with an enterprise router, remove the AS_Path list from the route policy by referring to Modifying a Policy Node in a Route Policy.
- Click
in the upper left corner and select the desired region and project.
- Click Service List and choose Networking > Enterprise Router.
The Enterprise Router homepage is displayed.
- In the navigation pane on the left, choose Routing Control > AS_Path Lists.
The AS_Path Lists page is displayed.
- Locate the row that contains the AS_Path list you want to delete and click Delete in the Operation column.
A confirmation dialog box is displayed.
- Click OK.
Deleted AS_Path lists cannot be recovered.
