AS_Path List Overview
Introduction
An AS_Path list is a collection of filters that are used to filter BGP routes based on AS_Path attributes contained in BGP routes. AS_Path attributes record the number of each AS that BGP routes pass through from the source to the destination in distance-vector order.
If two AS_Paths both can enable communications, the AS_Path with a smaller ASN is preferred because it uses a shorter path.
AS_Path attributes are private attributes of BGP and AS_Path filters take effect only on BGP routes.
Match Rules
An AS_Path attribute can be regarded as a string containing spaces and is used to match routes through a regular expression.
As shown in Figure 1, the ASN of ER-A is 100. If a BGP route from the peer passes through ER-A, the ASN 100 of ER-A is automatically added to the left of AS_Path.
A regular expression is a string that describes a characteristic and verifies whether another string conforms to this characteristic. An AS_Path filter defines an AS_Path regular expression to match AS_Path attributes for filtering BGP routes.
- If a route matches an AS_Path filter with Action set to Allow, the route is allowed. If the AS_Path filter has Action set to Deny, the route is denied.
- If a route does not match any AS_Path filter in an AS_Path list, the route is denied.
An AS_Path list filters routes by sequential match, unique match, or deny by default.
- Sequential match: An AS_Path filter with a smaller number is matched first. AS_Path filters in an AS_Path list can be sorted by sequence number in different orders, leading to different filtering results.
- Unique match: If a route matches an AS_Path filter, it no longer tries to match other AS_Path filters.
- Deny by default: By default, routes that do not match any AS_Path filter in an AS_Path list are denied. If an AS_Path list has one or more deny filters, you need to create an AS_Path filter to allow all other routes.
AS_Path Regular Expressions
An AS_Path filter is essentially a regular expression. The content of a regular expression is complex. The following describes the AS_Path filter.
An AS_Path filter uses a regular expression to define matching rules. A regular expression consists of the following parts:
- Metacharacter: defines matching rules.
- General character: defines match objects.
Table 1 lists the metacharacters supported by BGP AS_Path regular expressions.
Metacharacter |
Description |
Example |
Matches AS_Paths with any single character except "\n", including spaces. |
.* matches any AS_Path or route.
If an AS_Path list has one or more deny filters, you need to create an AS_Path filter to allow all other routes. |
Matches AS_Paths with 0 or more sequences of the character before the asterisk "*". |
See the preceding example. |
Matches AS_Paths with 1 or more sequences of the character before the plus "+". |
65+ matches AS_Paths that begin with 6 and include one 5 or consecutive 5.
Matches any AS_Path with characters on either side of the vertical bar "|". |
100|65002|65003 matches 100, 65002, or 65003.
AS_Path examples that 100|65002|65003 matches:
Matches AS_Paths beginning with the characters that follow the caret "^". |
^65 matches AS_Paths beginning with 65.
Matches AS_Paths ending with the characters before the dollar sign "$". |
65$ matches AS_Paths ending with 65.
^$ matches null character strings (null AS_Path) and can be used to match the locally originated routes. |
Defines a subexpression. Both the expression and the subexpression must match. |
100(200)+ matches AS_Paths that begin with 100 and include one 200 or consecutive 200.
AS_Path examples that 100(200)+ matches:
Matches AS_Paths with any character in the brackets "[ ]". |
The characters in the brackets "[ ]" can only be numbers 0 to 9. To match AS_Paths within the range of 735 to 907, use (73[5-9]|7[4-9][0-9]|8[0-9][0-9]|90[0-7]). |
Matches AS_Paths without any character within the range specified in the brackets "[ ]". |
_ |
Matches AS_Paths with a sign, such as a comma ",", left brace "{", right brace "}", left parenthesis "(", right parenthesis ")", or space. The underscore "_" can be used at the beginning of a regular expression with the same function as the caret "^" or at the end of a regular expression with the same function as the dollar sign "$". |
Indicates an escape character. |
A backslash "\" is used to disable special functions of signs in regular expressions, such as the left parenthesis "(" and right parenthesis ")" in an AS_Confed_Sequence, the left bracket "[" and right bracket "]" in an AS_Confed_Set, and the left brace "{" and right brace "}" in an AS_Set.
Notes and Constraints
- By default, an account can have up to five AS_Path lists.
- By default, each AS_Path list can have up to 100 AS_Path filters.
- Changing an AS_Path list will also change the associated routes and traffic routing. To reduce the impact on network performance, an AS_Path list can only be changed once within 40 seconds.
