- What's New
- Function Overview
- Product Bulletin
Service Overview
- Infographics
- What Is DMS for RabbitMQ?
- Product Advantages
- Application Scenarios
- Specifications
- Comparing RabbitMQ, Kafka, and RocketMQ
- Comparing RabbitMQ AMQP-0-9-1 with Open-Source RabbitMQ
- Comparing RabbitMQ Versions
- Related Services
- Security
- Notes and Constraints
- Basic Concepts
- Exchanges
- Permissions Management
- Billing
- Getting Started
User Guide
- Process of Using RabbitMQ
- Buying a RabbitMQ Instance
- Configuring Virtual Hosts
- Accessing a RabbitMQ Instance
- Managing Messages
- Advanced Features
Managing Instances
- Viewing and Modifying Basic Information of a RabbitMQ Instance
- Viewing RabbitMQ Client Connection Addresses
- Managing RabbitMQ Instance Tags
- Configuring RabbitMQ Recycling Policies
- Resetting the RabbitMQ Instance Password
- Enabling RabbitMQ Plug-ins
- Exporting the RabbitMQ Instance List
- Deleting a RabbitMQ Instance
- Logging In to RabbitMQ Management UI
- Modifying RabbitMQ Instance Specifications
- Migrating RabbitMQ Services
- Testing Instance Performance
- Applying for Increasing RabbitMQ Quotas
- Viewing Metrics and Configuring Alarms
- Viewing RabbitMQ Audit Logs
Best Practices
- RabbitMQ Best Practices
- Automatic Recovery of a RabbitMQ Client from Network Exceptions
- Automatic Consumer Reconnection After a RabbitMQ Node Restart
- Improving RabbitMQ Performance
- Configuring Queue Load Balancing
- Deduplicating Messages Through Message Idempotence
- Suggestions on Using DMS for RabbitMQ Securely
- Developer Guide
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs V2 (Recommended)
- Out-of-Date APIs
- Appendix
- Change History
- SDK Reference
Instances
- What RabbitMQ Version Does DMS for RabbitMQ Use?
- What SSL Version Does DMS for RabbitMQ Use?
- Why Can't I View the Subnet and Security Group Information During Instance Creation?
- How Are Requests Evenly Distributed to Each VM of a Cluster RabbitMQ Instance?
- Do Queues Inside a Cluster RabbitMQ Instance Have Any Redundancy Backup?
- Does DMS for RabbitMQ Support Data Persistence? How Do I Perform Scheduled Data Backups?
- How Do I Obtain the Certificate After SSL Has Been Enabled?
- Can I Change the SSL Setting of a RabbitMQ Instance?
- Can RabbitMQ Instances Be Scaled Up?
- Does RabbitMQ Support Two-Way Authentication?
- Does DMS for RabbitMQ Support CPU and Memory Upgrades?
- How Do I Disable the RabbitMQ Management UI?
- Can I Change the AZ for an Instance?
- How Do I Obtain the Region ID?
- Why Can't I Select Two AZs?
- How to Change Single-node RabbitMQ Instances to Cluster Ones?
- Can I Change the VPC and Subnet After a RabbitMQ Instance Is Created?
Connections
- How Do I Configure a Security Group?
- Why Does a Client Fail to Connect to a RabbitMQ Instance?
- Does DMS for RabbitMQ Support Public Access?
- Does DMS for RabbitMQ Support Cross-Region Deployment?
- Do RabbitMQ Instances Support Cross-VPC Access?
- Do RabbitMQ Instances Support Cross-Subnet Access?
- What Should I Do If I Fail to Access a RabbitMQ Instance with SSL Encryption?
- Can I Access a RabbitMQ Instance Using DNAT?
- Why Can't I Open the Management Web UI?
- Can a Client Connect to Multiple Virtual Hosts of a RabbitMQ Instance?
- Why Does a RabbitMQ Cluster Have Only One Connection Address?
- Do RabbitMQ Instances Support the Ping Command?
- Messages
- Monitoring & Alarm
Instances
- Videos
More Documents
- Getting Started
- Managing Messages
- Advanced Features
Managing Instances
- Using the rabbitmq_tracing Plug-in
Instances
Connections
- Messages
Instances
- Change History
- API Reference (ME-Abu Dhabi Region)
- Preparing the Environment
- Buying an Instance
- Operating RabbitMQ Instances
- Quotas
- Monitoring
- Auditing
Instances
- What If One RabbitMQ VM Fails to Be Restarted When a Cluster RabbitMQ Instance Is Being Restarted?
- Does DMS for RabbitMQ Support MQTT?
- How Do I Clear Queue Data?
Connections
- Does DMS for RabbitMQ Support Cross-VPC Access?
- Does DMS for RabbitMQ Support Cross-Subnet Access?
- Plug-ins
- Messages
Instances
- Change History
- API Reference (Kuala Lumpur Region)
Creating a RabbitMQ Queue
Queues store messages. Each message is sent to one or multiple queues. Producers produce and send messages to queues, and consumers pull messages from queues for consumption.
Multiple consumers can subscribe to one queue. In this case, messages in the queue are distributed to the consumers, and no consumer can have all messages.
This section describes how to create a queue on the console.
A virtual host has been created.
- Log in to the console.
- In the upper left corner, click
and select a region.
Select the region where your RabbitMQ instance is.
- Click
and choose Middleware > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
- Click an instance name to go to the instance details page.
- In the navigation pane, choose Virtual Hosts.
- Click a virtual host name.
- On the Queue tab page, click Create Queue. The Create Queue dialog box is displayed.
- Configure the queue name and other parameters by referring to Table 1.
Table 1 Queue parameters Parameter
Name
When creating a queue, you can modify the automatically generated queue name. Naming rules: 3–128 characters and only letters, digits, percent signs (%), vertical bars (|), hyphens (-), underscores (_), slashes (/), or backslashes (\).
The name cannot be changed once the queue is created.
Persistence
This parameter is mandatory for RabbitMQ 3.x.x instances, and enabled by default for RabbitMQ AMQP-0-9-1 instances.
Indicates whether to enable queue persistence.- Enabled: The queue survives after server restart.
- Disabled: The queue will be deleted after server restart and needs to be recreated.
Auto-Delete
Indicates whether to enable automatic queue deletion.
- Yes: The queue will be automatically deleted when the last consumer unsubscribes from the queue.
- No: The queue will not be deleted when the last consumer unsubscribes from the queue.
Dead Letter Exchange
Select an exchange for dead letter messages.
Dead Letter Routing Key
Enter a dead letter message routing key. The dead letter exchange sends dead letter messages to the queue with a binding key that corresponds to this routing key.
Time to Live
Indicates how long messages can remain, in ms. If the time to live passed and messages are still not consumed, they become dead letter messages and are sent to the dead letter exchange.
Highest Priority
Only RabbitMQ AMQP-0-9-1 has this parameter.
Priority of a queue. Range: 1–9. The larger the value, the higher the priority.
Lazy Queue
Only available for RabbitMQ 3.x.x instances.
Enter lazy to make the queue lazy.
Lazy queues store as many messages to the disk as possible. Messages are loaded to the memory only when they are being consumed. This reduces memory consumption.
- Click OK.
View the created queue on the Queue tab page.
