Updated on 2025-11-20 GMT+08:00
Enabling RabbitMQ Plug-ins
After creating a RabbitMQ instance, you can enable add-ons through plug-ins. The plug-ins are disabled by default when the instance is created.
RabbitMQ plug-ins can be used for testing and service migration. Do not use them for production. Reliability issues caused from using plug-ins are not within commitments on SLAs. For details, see Service Overview > Notes and Constraints.
Table 1 lists plug-ins supported by RabbitMQ. The ports of the plug-ins cannot be changed.
Table 1 Plug-ins
Name
Function
Port
rabbitmq_federation
Federation
rabbitmq_shovel
Message moving
rabbitmq_consistent_hash_exchange
Support for x-consistent-hash. x-consistent-hash exchanges can be created after this plugin is enabled.
  • Unavailable for RabbitMQ AMQP-0-9-1.
  • To enable plug-ins for RabbitMQ instances created before July 1, 2020, submit a service ticket.
  • To enable plug-in rabbitmq_consistent_hash_exchange for RabbitMQ instances created before November 14, 2020, submit a service ticket.
  • Enabling plug-ins does not restart instances.
  • The rabbitmq_shovel and rabbitmq_federation plug-ins can be enabled only for specific instances. For details, see Table 2.
    Table 2 Instances for which plug-ins can be enabled
    Instance
    rabbitmq_shovel
    rabbitmq_federation
    Single-node instances with SSL disabled
    Supported
    Supported
    Single-node instances with SSL enabled
    Not supported
    Not supported
    Cluster instances with SSL disabled
    Not supported
    Supported
    Cluster instances with SSL enabled
    Not supported
    Not supported
  1. Log in to the RabbitMQ console.
  2. In the upper left corner, click and select a region.
  3. Click the desired instance to view its details.
  4. In the navigation pane, choose Instance > Plug-ins. Then, click Enable in the row containing the desired plug-in.
    Confirm that you want to enable the plug-in and wait for it to be enabled successfully.
