Updated on 2025-07-14 GMT+08:00
Resetting the RabbitMQ Instance Password
If you forget the password of a RabbitMQ instance, reset the password so that you can normally access the instance.
Notes and Constraints
Unavailable for RabbitMQ AMQP-0-9-1.
Prerequisite
The instance must be in the Running state.
  1. Log in to the RabbitMQ console.
  2. In the upper left corner, click and select a region.
  3. Reset the instance password using either of the following methods:
    • In the row containing the desired instance, choose More > Reset Password.
    • Click the desired RabbitMQ instance to view its details. Choose > Reset Password in the upper right corner.
  4. Enter and confirm a new password, and click OK.
    • If the password is successfully reset, a success message will be displayed.
    • If the password fails to be reset, a failure message will be displayed. If you still fail to reset the password after multiple attempts, contact customer service.
      A success message is displayed only after the password is successfully reset on all brokers.
